Activity › Forums › AJA Video Systems › No 4ch output over SDI?
Posted by Tim Irwin on June 13, 2007 at 7:41 pmHi,
I’m having trouble getting my 4 channel timeline to output 4 ch audio over SDI to my A500 digibeta deck. No matter what settings i choose in the audio output tab of the sequence settings window, It still mixes down to tracks 1 and 2 on the digibeta deck. I’m running a g5 dual 2.3 kona LH, FCP 5.1.2. Any thoughts appreciated
-Tim
Jeremy Garchow replied 19 years, 3 months ago 5 Members · 6 Replies -
Tim Irwin
June 13, 2007 at 7:45 pmJust figured it out. For the benefit of anyone with the same problem, If you change the settings in the audio output tab after you have edited into it, it has no effect. After I created a new seq with the appropriate settings and pasted the contents of the original seq into it, the 4ch output worked.
thanks, tim
Jeremy Garchow
June 13, 2007 at 8:08 pmDid you forget to turn off the down mix button on the audio mixer?
Steve Covello
June 13, 2007 at 9:51 pmIf it worked, great, but I don’t think you needed to do that.
Change the audio settings on the A/V Settings, but then you need to do cmd + 0 [zero] on the sequence in your bin and change the audio settings in the audio tab there too. then set the audio track to the proper channel by ctrl + click next to the track light [sorry, Avid term] to designate the channel patch.
I’ve always wished Apple would change this dopey procedure in a next version of FCP.
steve covello
Walter Biscardi
June 14, 2007 at 10:03 am[Tim Irwin] “Just figured it out. For the benefit of anyone with the same problem, If you change the settings in the audio output tab after you have edited into it, it has no effect.”
Actually that’s incorrect. You can change the Audio Output tab at any point during your edit. I output 4 channel shows all the time and generally leave the timeline as a 2 channel mix until we’re ready to master. Then I switch the outputs to 4 channel and assign the audio tracks accordingly. You do not need to create a fresh timeline to do this.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
John Pale
June 14, 2007 at 1:01 pmSounds like you changed the overall preference instead of the settings of your sequence.
Changing the preferences changes the output for all NEW sequences, but has no effect on the existing ones.Unlike Avid, FCP can have multiple projects and sequences open at the same time…and each open sequence can have its own audio output setting.
Jeremy Garchow
June 14, 2007 at 3:36 pmYou can also setup a 4 channel output sequence, then simply hit the downmix button on the FCP audio mixer and monitor two channel. Super handy for four channel mixes and two channel monitoring.
Jeremy
