Activity Forums Adobe Premiere Pro Nikon D800 & Panasonic HMC71e video
  • Nikon D800 & Panasonic HMC71e video
    Posted by Jonathan Hudson on July 3, 2014 at 7:30 pm
    Hi every one. Using a Panasonic HMC71e with CS5 for a long time with no problems, very pleased. However I have just bought a Nikon D800 and am wondering if I can import both to a project. What setting should I use? When I look at a Panasonic HMC71e file it says it is 1440×1080 25fps-it is an MPEG file. The D800 says 1920 x 1080 25fps, it is a QuickTime file. This is where I become confused, is there a project setting which means I can use both on the same timeline. Thank you.
    Jonathan Hudson replied 12 years, 2 months ago 2 Members · 2 Replies
  • John Gurney
    July 3, 2014 at 7:59 pm
    I would start a project, bring footage in from both camera’s and then right-click a clip from the D800 and select “New Sequence From Clip. Premiere will then up-size anything from the panasonic to match the D800 sequence. I do it all the time.
  • Jonathan Hudson
    July 3, 2014 at 11:07 pm
    Sounds like a very simple solution so thank you, I will indeed try that.
