Activity › Forums › Apple Final Cut Pro Legacy › Nikon D5000 HD footage import into FC
  • Nikon D5000 HD footage import into FC
    Posted by Jared Eaton on January 24, 2010 at 7:34 am
    I need help. What should my sequence settings be for working with hd 720p 24fps .AVI files in Final Cut? I can import them fine, but it wants me to render every time i put a clip on the timeline. Any suggestions?
    jared
    Greg Barringer replied 16 years, 8 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    January 24, 2010 at 3:20 pm
    Select all those AVI’s and open them in Compressor. From there transcode them all to ProRes using the same frame rate and size you’ve shot. Don’t edit the AVI’s directly… you’ll see no loss in this process and you’ll be a very happy camper.
    I’d use LT for cuts/dissoves sort of work, Regular ProRes is better, but likely won’t see it unless you’re compositing a lot. Or ProRes HQ if you have a lot of fast action in the shots.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Greg Barringer
    January 24, 2010 at 7:19 pm
    Use Compressor first and convert the .AVI files to Apple ProRes 422.
    That’s what I do with the D3S. It works.
    Oops, Jerry and I must have posted at the same time.
