Activity Forums Apple Motion Next problem — Has anyone gotten Master Templates to work?
  • Next problem — Has anyone gotten Master Templates to work?
    Posted by Wayne Franklin on July 20, 2007 at 5:56 pm
    I searched the forums, and this topic doesn’t seem to have come up, yet. Maybe I’ll check over in FCP.
    Anyway, I did everything as instructed in both the Motion manual and the FCP manual to create a Motion master template, edit it into my FCP sequence and then open the Controls tab in the Viewer. I drag my clip, with ins and outs set, to the clip well in the Viewer. A thumbnail shows up in the well and the source file is listed properly, but nothing changes in the actual sequence. In the Canvas, I still see the drop zone icon where the new clip should be.
    Are there workarounds or known issues here?
    The cheese stands alone.
    Wayne Franklin replied 19 years, 1 month ago 2 Members · 2 Replies
  • Noah Kadner
    July 20, 2007 at 6:23 pm
    What sort of clip- remember it should be standard QT media preferably trimmed to exactly what you want to use.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Wayne Franklin
    July 20, 2007 at 6:48 pm
    It’s an HDV 1080i60 project, as are all of the clips. All footage was loaded using the HDV capture settings in FCP. I am using a subclip. I tried making it a master clip, but that didn’t work either.
    After your message, I thought it might be an HDV issue. So I exported a reference movie of the same clip from FCP, imported it into Motion, dropped it into the appropriate drop zone, and VOILA! It worked as expected.
    I just want this thing to work as advertised. I need to be able to easily customize these animations within FCP for efficiency’s sake. (Of course, how efficient is spending all my time trying to solve workflow bugs?) Otherwise, I never would have bothered with Motion and just knocked it out in AE.
