Activity › Forums › Media 100 › Next Clip In Bin Double Skips – Bug?
  • Next Clip In Bin Double Skips – Bug?
    Posted by Michael J c on May 3, 2006 at 12:48 am
    Does anyone else have this issue?
    When I use the next or previous clip buttons in the edit suite (to jump to the next clip in the bin), about 90% of the time it will jump ahead 2 clips (skiping the next clip). This makes it so you are forced to go back to click on each clip you’re scanning individually…
    …and on a dual monitor setup, this can be annoying. Anyone else with this problem?
    Running 10.1.4 M100HD.
    Michael J c replied 20 years, 5 months ago 3 Members · 4 Replies
  • Thomas Hughes
    May 4, 2006 at 9:43 pm
    I have the same problem, I don’t know the fix.
  • Michael J c
    May 5, 2006 at 12:05 am
    I don’t think there is a fix… It is just a really annoying bug. 🙁
  • Abercrombie Pupputnick
    May 5, 2006 at 9:18 pm
    The problem is that the button repeats while you hold it down. That might be useful in a giant bin if you want to cruise past a bunch. It seems to repeat a little too quickly. But you should be able to click quickly and beat the repeat.
  • Michael J c
    May 6, 2006 at 1:22 am
    Nice! You nailed it. That’s right.. thanks. I think they need to give that about a .5 delay eh?
