Activity › Forums › Maxon Cinema 4D › Newton Field
  • Newton Field
    Posted by Emptythetill on August 21, 2007 at 8:47 am
    Hi all.
    OK, after using Maya since 1 I have been forced to use C4D for my latest job. Been on it 3 days, it seems very simple and fun but there is something I just can’t get to work.
    Particles. I have a need to create a small explosion of 10,000 particles over 3 frames from a point. They then need to slow, turn and head back to where they came from and when they hit the origin they need to die. In Maya I would use a Newton field, I am assuming Cinema 4D can do this?
    Any help would be greatly appreciated.
    Take care.
    A.
    Adam Trachtenberg replied 19 years, 1 month ago 3 Members · 3 Replies
  • Arndt Von koenigsmarck
    August 21, 2007 at 9:08 am
    what particles are you using? Thinking Particles or the build in system?
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
  • Adam Trachtenberg
    August 21, 2007 at 1:41 pm
    I would use Thinking Particles with a PGravity node set to Spherical. Go to the point of desired maximum expansion and then create a sphere that encompases that volume. Use it as your gravity object in the PGravity node. Easiest way is probably to keyframe the gravity strength, which will take a little experimention. Then set particle life to the frame where the particles collapse back on themselves.
  • Adam Trachtenberg
    August 21, 2007 at 1:42 pm
    btw, if you have the MoGraph module you could do this very precisely by cloning onto a sphere and simply keyframing the sphere’s scale.
