Activity › Forums › Adobe After Effects › Newton 2 falling paper
Posted by Chris Behl on September 8, 2015 at 10:16 amDoes anyone know how to make a rectangle fall like a piece of paper?
cheers.
Chris Behl replied 11 years ago 2 Members · 2 Replies -
John Cuevas
September 8, 2015 at 1:14 pmI made a project a few years ago where letters were falling out of the sky, fluttering a little by the wind. Basically, just using a sin curve to move them back and forth in x and z space, along with some y rotation.
Here’s an updated version of that project. The controller null is where you can change the how often the flutters are(_Freq) and how big they are(_Amp or _Max Tilt). In the project I uploaded, I keyframed the _Freq of each property to get it to stop fluttering. And it’s set up so that you can use position keyframes on your object to move it into place.
Take a look, it might help you on your project or give you some ideas to try out.
Johnny Cuevas, Editor
ThinkCK“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb.
