NewBlue Essentials III – Split Screen
Posted by Roger Bansemer on November 25, 2012 at 2:00 pmThe NewBlue Essentials III “Split Screen” plugin looks great except that I can’t eliminate the ghost image bleeding over into the adjacent split screen.
Is anyone else having this problem or know how to correct it?
RogerRoger Bansemer
Edward Troxel replied 13 years, 10 months ago 3 Members · 8 Replies -
Theo Van laar
November 25, 2012 at 3:43 pmWhat happens if you put line width and feather to zero?
Theo
Theo Van laar
November 25, 2012 at 4:17 pmThat’s strange, I can not reproduce this. Do you have the Level for the upper track at 100%?
Theo
Roger Bansemer
November 26, 2012 at 12:36 amThe levels on both layers are at 100%.
I’ve applied the plugin to the top layer.
I just can’t figure it out.Roger Bansemer
Edward Troxel
November 26, 2012 at 11:20 pm -
Roger Bansemer
November 27, 2012 at 2:13 amThanks very much. I shall try it and let you know.
Thank goodness for the forum and all those that help each other.
ThanksRoger Bansemer
Roger Bansemer
November 27, 2012 at 1:47 pmHello Edward,
Thanks for that link. This one works fine. I installed it over the other one and I’m assuming that if I install it on my PC my serial number will work from the prior download.
Thanks again.Roger Bansemer
