Activity Forums VEGAS Pro Newbie to forum – struggling with creating a DVD Architect Studio 5 project
  • Newbie to forum – struggling with creating a DVD Architect Studio 5 project
    Posted by Lisa Reid on January 31, 2016 at 9:06 am
    I am new to this forum – hope you can help.
    I have made a number of small videos using Movie Studio Platinum 13.
    I want to now create a multi-title DVD project.
    However, when I am unable to do so.
    When making a single title DVD there is no issue.
    When I attempt to add one of the titles to a compilation DVD and error message comes up stating “the selected file is not of the required type”.
    What am I doing wrong?
    Lisa
    Doug Jackson replied 10 years, 7 months ago 3 Members · 2 Replies
  • John Rofrano
    January 31, 2016 at 2:17 pm
    [Lisa Reid] “When I attempt to add one of the titles to a compilation DVD and error message comes up stating “the selected file is not of the required type”.”
    For DVD you should use Project | Render As… and render your video to MainConcept MPEG2 using one of the DVD Architect … templates and render your audio to Dolby Digital AC3 and give it the same filename (except with the .ac3 extension, of course). You can then drop these into DVD Architect and it will accept them.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Doug Jackson
    January 31, 2016 at 2:56 pm
    Hi Lisa,
    I only have access to DVD Architect Pro, but I’m pretty sure the Studio version allows creation of DVDs with multiple titles.
    Assuming you’ve rendered your movies as John has recommend, you would create a “Menu-Based Disc” in DVD Architect and then use the Add Media for the additional titles. Menu based disc is usually the default in DVDA. Once the Menu page is up, right click on the Project Overview panel on the left side and select “Insert Media” for each of your Movies.
    Dell Precision T5500
    2x Intel Xeon DP E5620 @ 2400MHz; Memory: 22528MB; Chipset:Intel 5520;
    Video Card : AMD R9 290x
    HDD: Crucial_SSD1 (256GB);WD(1000GB);WD(2000GB)
    OS: Windows 7 Pro SP1 (64-bit)
