Activity Forums Canon Cameras Newbie to editing 5d footge in final cut pro. what sequence settings should i use?
  • Newbie to editing 5d footge in final cut pro. what sequence settings should i use?
    Posted by Kurt Hudson on November 11, 2009 at 4:28 pm
    Everytime I change the sequence settings to clip settings the video plays without having to render but its choppy as hell… but when I change to apple pro res HQ I have to render 20 minutes each clip but they play fine… how do I set the sequence settings to where the video plays smooth without having to render each time? Thanks!!!!
    Brent Dunn replied 16 years, 10 months ago 2 Members · 1 Reply
  • Brent Dunn
    November 11, 2009 at 7:14 pm
    Check out my post below. There is a link to free software for converting your 5D footage.
    Even though the footage is .MOV, Final Cut uses ProRes for HD editing. That is Apple’s preferred codec. You’ll have to convert the footage using the software to proRes, then you won’t have to render and it’ll perform as it should.
    You can also use Compressor, but there are many issues with Compressor crashing with trying to convert the files.
    You can edit in iMovie the files as they are, right out of the camera.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Video.com
