Activity Forums Adobe Premiere Pro Newbie question on video/audio in menu
  • Newbie question on video/audio in menu
    Posted by Mark Thoma on February 25, 2009 at 6:22 pm
    Hi everyone.
    Brand new to this forum, and don’t know that I even belong here. I’m in the process of authoring a leave-behind DVD for potential customers of my small business. I’m using Premiere Elements 2 but have access to Premiere Pro should I need to go that way. But currently Elements 2 does everything I need….until now.
    The program only allows a 30 second long video/audio background for the DVD menu…and then the video/audio loops endlessly. I would like to use the menu background as a location for a 1 minute long introduction that ends with a graphic and doesn not loop. I.E. me on-camera saying “Hi My name is Mark Thoma and I’d like to tell you about….” as soon as the DVD is inserted. Ideally the menu ‘buttons’ for the three ‘sample’ videos about my company would appear near the end of my on-camera introduction but I could live with the buttons being on the screen the entire time.
    Is there inexpensive software available that does what I need or am I better off taking my files to a commercial production house?
    Thanks in advance.
    Mark Thoma
    Chris Buttacoli replied 17 years, 6 months ago 2 Members · 3 Replies
  • Chris Buttacoli
    February 25, 2009 at 6:59 pm
    Not sure what is expensive to you – Adobe Encore 2.0 will allow you to set a clip as “play first”, before switching to the menu. But Encore does have a steep learning curve. New CS4 versions cost $800, but I’ve seen older CS3 versions for around $350 online.
  • Mark Thoma
    February 25, 2009 at 7:15 pm
    hey thanks Chris,
    Like I said I have access to Premiere Pro. Should Encore be bundled with it? And $350 is pretty pricey for authoring one DVD. At least for me in the start-up mode. I assume Encore will allow me to use whatever length video in the ‘play first’ before the menu pops up?
    mark thoma
  • Chris Buttacoli
    February 26, 2009 at 5:46 am
    Encore is bundled with the Adobe Suite, not built in to Premiere Pro. It is a seperate program, and for one DVD it is way too expensive. But you can use any length video as ‘play first’. Check to see what you have access to.
