Activity Forums AJA Video Systems Newbie Question on Format Conversion Kona 3
  • Newbie Question on Format Conversion Kona 3
    Posted by Paul Burgess on February 24, 2008 at 3:01 pm
    Is there anyway that i can use a Kona3 card to convert on QT file on my hard drive to another format also save on the hard drive without exporting the clip outside?
    Jeremy Garchow replied 18 years, 6 months ago 2 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    February 24, 2008 at 7:29 pm
    hey paul. Can you please explain exactly what you are trying to do?
    What codec to what codec?
  • Paul Burgess
    February 24, 2008 at 9:40 pm
    Thanks for your response.
    An example would be that I have PAl DV file on the disc and want to convert it to any HD format so that I end up with say a QT HD version of the file.
    Paul
  • Jeremy Garchow
    February 25, 2008 at 1:14 am
    No. The Kona only works with feeding video signals to it not with Quicktime files on disc. If you feed a DV-PAL SDI signal to the Kona3, then you can upconvert and capture a PAL HD file in 1080 or 720. FOr file based upconversions there are plenty of options to choose from. Compressor doesn’t a decent job or you can pay for one from a number of companies.
    Jeremy
  • Paul Burgess
    February 25, 2008 at 8:20 am
    Thank you for clearing that up.
    Paul
  • Paul Burgess
    February 25, 2008 at 9:37 am
    When I feed in by firewire from a camera – say a DV source and choose a Kona codec to up convert – will the card then handle the up convert to the disc?
    Paul
  • Jeremy Garchow
    February 25, 2008 at 2:41 pm
    No as you are using the firewire port on the computer, not the Kona card.
    Make sense?
    Jeremy
  • Paul Burgess
    February 25, 2008 at 2:44 pm
    Makes sense – I just hoped that using the Kona codec would use the Kona processor.
    I was misinformed by the dealer.
    Thanks for your help.
    Paul
  • Jeremy Garchow
    February 25, 2008 at 3:37 pm
    [Paul Burgess] “Makes sense – I just hoped that using the Kona codec would use the Kona processor.
    I was misinformed by the dealer. “
    FOr the majority of it’s uses, the KOna uses codecs from FCP. If you feed SDI from a dv deck, you can up-convert your dv signal.
    Jeremy
