Activity Forums Storage & Archiving Newbie question about SCSI…
  • Newbie question about SCSI…
    Posted by Tom Elgin on July 28, 2012 at 9:38 pm
    I’ve just started dipping my toes into the world of SAN. I’m looking to switch gears a bit and moving from networking (think Cisco routers/switches) into the world of storage area networks.
    One thing that’s not clear to me is the SCSI protocol. The only SCSI I’m familiar with are SCSI hard drives. Does the SCSI protocol have anything to do with SCSI drives? If so, in what respect?
    Tom
    Bob Zelin replied 14 years, 1 month ago 3 Members · 5 Replies
  • Alex Gerulaitis
    July 28, 2012 at 10:51 pm
    [Tom Elgin] “Does the SCSI protocol have anything to do with SCSI drives? If so, in what respect?”
    SCSI “…is a set of standards for physically connecting and transferring data between computers and peripheral devices”, mostly hard drives. So there is a direct link between SCSI as a standard, and SCSI hard drives.
    SCSI in its parallel form (SCSI-1, Fast-, Wide-, Ultra-SCSI, etc.) is largely extinct, replaced by SAS (Serial Attached SCSI).
    Alex Gerulaitis
    Systems Integrator
    DV411 – Los Angeles, CA
  • Tom Elgin
    July 29, 2012 at 1:18 pm
    Thanks for clearing that up Alex. I never came across anything that definitively said it was both a physical spec, as well as a spec for how data was transferred.
    Tom
  • Alex Gerulaitis
    July 30, 2012 at 8:02 pm
    [Tom Elgin] “I never came across anything that definitively said it was both a physical spec, as well as a spec for how data was transferred. “
    Tom, was the Wikipedia article on SCSI confusing? It seems to say that right off the bat.
    Alex Gerulaitis
    Systems Integrator
  • Tom Elgin
    July 31, 2012 at 5:23 pm
    Alex, I guess I wasn’t clear. I meant that prior to that Wiki explanation, I hadn’t seen anything that clearly indicated it was both a physical spec, as well as a standard for transferring data.
  • Bob Zelin
    July 31, 2012 at 6:02 pm
    Hey Tom –
    I will trade you some knowlege about SAN networks, and shared storage, if you can teach me some basics about Cisco CLI command structure, and some of the basic commands that I run into.
    I assume you are familiar with the Catalyst series, like the 4948
    Bob Zelin
