[Binny Singh] “Pardon me if this post sounds too amateurish to you but i have to ask.”
Rarely can you fault someone for asking a question they don’t know the answer to.
[Binny Singh] ”
1) Is there a SD format that shoots 10 bit video?”
Not to tape. Digibeta can record 10bits, but the cameras are 8bit.
[Binny Singh] “2) If all the abovesaid formats are 8 bit videos then is it possible to convert them to 10 bit( I guess Aja Kona3 or IO Hd can do that) ?”
You can capture your 8bit tape to a 10bit codec (such as ProRes or 10b Uncompressed) but it won’t necessarily add quality to your video, although anything you do to it from then on will maintain the utmost quality. If you produce graphics in 10bit, then you have the luxury of maintaing quality there as well. When I worked in SD, I always produced and mastered in 10bit (even though the tape format was 8bit), as I do know in HD, although it’s compressed 10bit as opposed to uncompressed 10 bit.
[Binny Singh] “3) If the answer to my second question is yes, then Does it really make any significant change in the video quality?”
You know what they say, beauty is in the eyes of the beholder. Some people are just fine with 8 bit video. It really depends on your material. If you produce a lot of graphics and do heavy color correction with some gradients, then you are going to want to work in 10bit. If non of that matters, then you can probably suffice in 8bit. I always try and work 10bit whenever possible and the codec we use to shoot with is 10bit right out of the box. It looks great and does us well, but it’s HD and not SD. Also, when using tape sources and capturing over baseband video (SDI or analog component) the video gets nicely decompressed through the deck hardware allowing a very nice capture of 8bit material in a 10bit space. If you stay native (say dv50 or some other firewire capture process) I found that the image quality was not as good as when I captured with a capture card/io device into a 10bit codec.
Hope that helps.
Jeremy
