Activity › Forums › Maxon Cinema 4D › newbie: C1, R1 – R not working….
  • newbie: C1, R1 – R not working….
    Posted by Kurt Murphy on March 26, 2007 at 3:22 pm
    Every time that I have an edge and I add a material to either R1, R2, C1, C2… it rarely works correctly. I set tags for them both, but the 2nd material seems to overide the first material… OR niether shows up… what am I doing wrong?
    thanks,
    kurt murphy
    Tim Shetz replied 17 years, 1 month ago 4 Members · 3 Replies
  • Nolan Scott
    March 27, 2007 at 12:18 pm
    Please make sure that the colour for the out- and inside body of your extruded text-spline occupies the first position in the object-manager and doesn
  • Taylor Gaussoin
    August 28, 2009 at 1:00 am
    Hey,
    Were you able to solve this problem? Im having the same one and cant figure it out!? Thanks
    Taylor
  • Tim Shetz
    August 28, 2009 at 6:16 am
    The main body color for the extrude should be the first tag, then you can add the color for your fillet with the R1 or R2 selection or the color for your cap with the C1 or C2 selection.
    Doesn’t matter which order they are in after the main body color. If that texture tag falls AFTER the other two, it will override it.
    Hope that helps.
    Tim
