Activity Forums VEGAS Pro Newbie: Best way to insert in the middle of a project?
  • Newbie: Best way to insert in the middle of a project?
    Posted by Darren Addy on June 30, 2009 at 1:42 pm
    Greetings all,
    I’m a relative newbie to Vegas Movie Studio 9 and I’m trying to figure out the best way to insert something in the middle of a project. My project has video, stills, voice over and music background and I have lots of transitions timed just the way I want them and voiceover & transitions to the clips.
    Is there a (relatively) easy way to move everything (except the background music) TOGETHER to allow for something I forgot to get inserted?
    Thanks in advance for any tips or pointers.
    Erik Davis replied 16 years, 10 months ago 4 Members · 3 Replies
  • John Rofrano
    June 30, 2009 at 3:18 pm
    Turn on Ripple Edit (Ctrl+L) with the option All Tracks, Markers, and Regions. Place your timeline cursor where you want to insert time and press the S key to split all tracks. Then just drag any event to the right and all will follow. Finally turn off Ripple Edit.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Terry Esslinger
    June 30, 2009 at 6:38 pm
    I believe you need to Select All and Group first.
  • Erik Davis
    June 30, 2009 at 8:17 pm
    Actually not so. All you have to do is turn ripple on. You only have to split if you need to cut a clip. Otherwise grab ANY EVENT (mouse drag) with ripple turned on and every event equal to or behind that event will move down the timeline. Very easy and I use it all the time.
    Erik
