Activity › Forums › Compression Techniques › Newbie advice on DVCPRO HD 1080i COMPRESSION
  • Newbie advice on DVCPRO HD 1080i COMPRESSION
    Posted by Steve Brown on October 11, 2011 at 7:16 am
    Hi everyone,
    I was hoping you could point me in the right direction. I am a complete novice at this video capture and compression but i have been asked to do a project at work that involves HD capture and then compression for archiving while keeping a high quality.
    My camera is a Panasonic AW-HE50S HD pan tilt camera which we use to capture sporting events in a stadium with settings at 1080i
    The footage is captured in a Apple PRO with a AJA KONA 3G card straight into Final Cut studio.
    I am getting a QT file at 115m/bits per sec around a 1Gb per minute in DVC PRO HD.
    This footage is great for the initial viewing, ( apart from some ghosting issues on ball movement through the air?) but i need to compress this for archiving, while keeping a reasonably high quality as the footage will be used again and viewed on large HD screens ( Panasonic 103″)
    I have tried different things from the Elgato H264 HD stick to some of the settings in Compressor but haven’t quite found that sweet spot.
    I have files of 100Gb that i need to compress down to 20Gb or below if possible.
    Any advice would be greatly appreciated
    Regards Steve
    Steve Brown replied 14 years, 11 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    October 11, 2011 at 11:07 am
    [Steve Brown] “This footage is great for the initial viewing, ( apart from some ghosting issues on ball movement through the air?) but i need to compress this for archiving, while keeping a reasonably high quality as the footage will be used again and viewed on large HD screens ( Panasonic 103”)
    Steve – I’d suggest biting the bullet and saving the QuickTime files as they are. They’re perfect for archiving – they’ll remain exactly the quality you captured them at. They’ll playback decently too!
    If you want to compress them for playback (not for archival), I’d suggest the apple TV 2 legato (or compressor) setting. Both should produce a 1080 file that is smaller but plays back great.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Steve Brown
    October 15, 2011 at 7:15 pm
    Many thanks for the advice.
    Regards Steve
