newbie — add time
Say you’ve got a series of elements that appear on screen for two seconds, and after the fact you realize that one right in the middle would work better if it was three seconds. Adding the time to that element is easy enough, but now everything following it is off by 1 second.
Is there an easy way to shift everything after a certain point over?
