Activity › Forums › Adobe Premiere Pro › Newb question on ingesting AVCHD files
  • Newb question on ingesting AVCHD files
    Posted by Mark Welch on October 8, 2011 at 4:31 pm
    Just jumped over from FCP. I am ingesting AVCHD from my AF-100. Audio channels 1 & 2 are being brought in as a stereo pair. In FCP there was a simple workaround. In Premier, I navigate up to Clip/Audio Options/ but.. Breakout to Mono is greyed out.
    How do I break up this stereo pair? I’m hearing boom mic and onboard cam mic mixed together.
    BTW – Premier is awesome. No regrets shelling out the $ for Production Premium. Thanks for any help.
    Ben G unguren replied 14 years, 11 months ago 2 Members · 3 Replies
  • Ben G unguren
    October 8, 2011 at 5:18 pm
    Did you right-click the clip in your project window and choose “Interpret Footage–>Audio”? (Or something like that.) I’m wondering if that takes you to a different set of options than what you already tried. There you can choose dual mono as the interpretation for the LR channels.
    Note that once a clip has been put into a timeline this cannot be changed. For just-from-fcp folks, this is somewhat startling and unexpected. If you’re in this boat, import another instance of your clip and try it with the new clip.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Mark Welch
    October 8, 2011 at 5:43 pm
    That’s it. I selected clip in the Project panel then went to Breakout to Mono but first had to select mono under the modify audio channels. maybe Adobe can streamline this a bit.
  • Ben G unguren
    October 8, 2011 at 9:31 pm
    It actually works pretty easily as long as you know what you want from the beginning.
    On some projects, I’ve actually XML’ed over to FCP, adjusted audio as I needed it, then XML’ed back to PPro. So I agree that a little more flexibility would be nice. But, at the same time, the way the two apps deal with audio in the timeline is pretty different. And there are some nice aspects to what PPro can do.
    Ben Unguren
