Activity Forums DaVinci Resolve New z820 build – Decklink 4k extreme issues…
  • New z820 build – Decklink 4k extreme issues…
    Posted by David Cox on June 12, 2013 at 12:36 pm
    Howdy all…
    New build HP Z820 dual Xeon 2670 Xeons, 128 GB ram, 20 TB raid 5 array pushing 1000MB+ read, K4000 GUI, Titan GPU, Decklink 4k extreme I/O Resolve full, Adobe CC.
    System is stable, and quick. The only problem I’m having is ouptut from the decklink. If it’s enabled in Resolve, I get 2 seconds of playback and then crash. Every time. No output. Disable decklink and I get 24fps on my BMCC footage with multiple nodes and noise reduction…
    If I select blackmagic playback in premiere, no output and GUI won’t play video, only audio. Un-tick blackmagic playback and GUI and functionality is fine.
    I anyone has lived through a similar experience and has any hints… I’d really appreciate it.
    Dave Cox
    Chip Murphy replied 13 years, 3 months ago 2 Members · 3 Replies
  • Chip Murphy
    June 25, 2013 at 11:53 pm
    Try and update the z820 firmware. I had a “PCI serr” BSOD error with my extreme 3d+ and a firmware update to the Z820 fixed it
  • David Cox
    June 26, 2013 at 12:32 am
    Thanks for your reply. I’m on the latest bios for the z820, do you know what bios you are using?
    I got a response from blackmagic, they are aware of the issue and are working on an updated driver.
  • Chip Murphy
    June 27, 2013 at 1:22 am
    David, the suite I had the issue with is now running v03.05
    My other labs are on 3.14
