Activity Forums Adobe After Effects New User Question
  • New User Question
    Posted by Mgruichjr on August 19, 2007 at 10:03 pm
    I am new to After Effects. Using CS3 for the first time, before this I had been using Sony Vegas 5 and 7. In After Effects, after I add video to a project along with effects, the changes do not carry over when I export to a new video file.
    Is there some step I am missing? I have also saved the projects, but still get the same result.
    Mgruichjr replied 19 years, 1 month ago 2 Members · 2 Replies
  • Michael Duff
    August 19, 2007 at 10:50 pm
    are you using the render queue to output your files? you should always use it…don’t use File->Export. If you have the composition selected that you want to render go to the menu “Composition->Add to Render Queue”. then adjust the settings to suit.
    Does this answer your question?
  • Mgruichjr
    August 21, 2007 at 8:57 pm
    Thanks! It took me a little bit, things have a different flow in this program.
    Michael
