Activity Forums Apple Final Cut Pro Legacy new user, just acouple of questions.
  • new user, just acouple of questions.
    Posted by Michael Ford on August 16, 2009 at 9:22 pm
    Hi, I have recently gone from using Avid Liquid to Final Cut Pro 7. i am getting to grips with the program but have a couple of questions.
    1. when slowing down clips can you choose options like you can in Avid Liquid. i.e Cut Frames, Mix Frames, Progressive, Cut & Mix Fields?
    2. Also i imported some old footage (720p) but when i play it back it it seems to stutter really badly. the file extension is mv2 if that helps.
    Any help will be greatly apreciated. Thank You.
    Rafael Amador replied 17 years ago 2 Members · 1 Reply
  • Rafael Amador
    August 17, 2009 at 11:38 pm
    [Michael Ford] “1. when slowing down clips can you choose options like you can in Avid Liquid. i.e Cut Frames, Mix Frames, Progressive, Cut & Mix Fields? “
    You have just a Frame Blending option.
    [Michael Ford] “2. Also i imported some old footage (720p) but when i play it back it it seems to stutter really badly. the file extension is mv2 if that helps.”
    That’s an MPEG-2 and probably won’t play very well in the time-line. See how it looks when rendered to QT. If it have problems, you should transcode it.
    Cheers,
    rafael
    http://www.nagavideo.com
