Activity Forums VEGAS Pro New to Vegas, need assistance with
  • New to Vegas, need assistance with
    Posted by Aldo Barani on April 6, 2015 at 9:48 pm
    joining tracks. Have used Corel Pinnacle Studio before (no expert though) and I use a copy of Vegas Pro 13 now.
    The problem I’m facing is this: when joining 2 or more video tracks, after the transition from track 1 to 2 (for example) the 2nd track displays briefly a still image from the end of the track before switching to the normal motion picture. Track 1 always run fine.
    What should I do to remove or avoid that? And how?
    Thank you.
    AB
    Jf Baez replied 11 years, 4 months ago 2 Members · 5 Replies
  • Jf Baez
    April 7, 2015 at 8:30 am
    Hello there, I am not an expert but I think you should tell us what video format you are using, since, In my opinion, my guess is that you could have a video format issue.
    are both clips the same format?
    Hope to see this solved.
  • Aldo Barani
    April 7, 2015 at 12:52 pm
    Sorry for missing that; the videos I’m trying to join are MP4 and where shot with a Sony Action Cam, therefore should work with the Vegas that is also a Sony product.
  • Jf Baez
    April 7, 2015 at 9:35 pm
    Ok I see your point, have you test it with different clips?
    is always the same result?
    if you render the project, is the output doing the same?
  • Aldo Barani
    April 8, 2015 at 10:57 pm
    I found the cause, it was because of the transition I have inserted between tracks.
  • Jf Baez
    April 9, 2015 at 4:10 am
    hahahahah good!! glad to know, cheers!
