Activity Forums VEGAS Pro New to Vegas (9)…which format to render?
  • New to Vegas (9)…which format to render?
    Posted by Ron Lukow on August 27, 2009 at 12:40 am
    Thank you for allowing me to address this forum.
    I’m new to Sony Vegas (vers 9). I’m a well-seasoned refugee from Pinnacle Studio. I have 2 questions re. procedures for Vegas 9. I video football & basketball games (high school). I utlize many fades & quite a bit of text & editing. However, I’m not sure which of the many formats available to render in? I didn’t have these choices in Studio. My movies end up being 45-60 minutes in length. I then burn them to hi-quality dvds for the player’s family’s viewing & keepsakes. Which would give me the best format to render in for a good dvd movie? My movies are not primarily aimed at Youtube presentation. Would I choose avi? or wmv? Or another?
    Also, I find that in Vegas, I cannot drag 2 projects onto the same line-view, is that right? I have to render them first, then combine them? Or, am I missing something. I often combine 2 basketball games onto 1 video if they were relatively short games.
    Thanks for your time & help. Am I leaving out any information needed?
    Ron
    Jeremy Rasnic replied 17 years ago 4 Members · 7 Replies
  • 7 Replies
  • Jeremy Rasnic
    August 27, 2009 at 4:15 pm
    You can, have two in the same project- it is called a nested veg. Just drag the veg file to the timeline.
    As for best render setting- use DVD architect (either widescreen or the other) depending on your format and then encode your audio as AC3. Then save those in the same folder with the same name. Open DVD Architect and point it to the video file and it will find the audio file automatically. Now it will not have to re encode the video as it is already compliant for DVD.
    Also, you can adjust the settings under the custom button to give a higher or lower bitrate depending on the length of your video.
    j razz
    https://www.jrazzcreations.com
  • Terry Esslinger
    August 27, 2009 at 4:57 pm
    To make a DVD you MUST have an MPEG2 file as that is the ‘language of DVDs’ You can increase or decrease the quality (and thus the size) of the MPEG2 by adjustong the bit rate. The most common way is to render to Main Concept DVDA compliant MPEG2 video stream (adjusting the bit rate as required) and to render a separate AC# audio file. Nmae both files the same (except for extension) and place them in the same folder. When you go to DVDA to make the DVD and drop the MPEG file in DVDA will automatically grab the associated AC3 file with it. No rerendering should be required in DVDA thus saving quality.
  • Ron Lukow
    August 27, 2009 at 11:10 pm
    Jeremy
    Thanks for help. I’m not sure how to render the audio file separately. I haven’t done that before. Or, is that a setting I make before rendering the .veg file into an mpeg2? I’ll hunt around a little.
    I have the Sony Architect, so I’ll make the video in there. I have in the past (Studio) always used Chapters. I assume Architect uses chapter similar to the way Studio worked.
    Thanks again.
    Ron
  • Ron Lukow
    August 27, 2009 at 11:13 pm
    Jeremy
    Thanks for reply. I wonder what I might be doing wrong. I’ve tried to drag the 2nd veg file into the existing timeline…no luck. I’ve tried dbl clicking on the veg file & making it open in the timeline with a veg file already sitting there…but no luck. Is there a Preference setting I have to change to make “nested veg files” work?
    Thanks again
    Ron
  • Jeremy Rasnic
    August 28, 2009 at 2:17 pm
    I would set your chapters in vegas (the “m” key) and then when you go to File-Render As make sure you check the box that says save markers…
    As for AC3 audio, just go to File- Render As and in the available templates choose one of the two AC3 templates and tweak it to how you want.
    For the video do the same thing as above and choose mpeg2 and DVDA Architect Video (or the widescreen if your footage is such) and render out from that. This one does not save audio with the file.
    j razz
  • Nhat Nguyen
    August 31, 2009 at 7:32 am
    My name is Max and this is my first time on this forum. I was looking for some post about “highest Quality” render out from Vegas 9
    and stumble into this one which somewhat related to my search, so Pls excuse me if i jump in the midle like this.
    I’ve been using Vegas since version 5 and render out as “Video for Window” and Template “NTSC DV” or “NTSC DV Widescreen” I did some rendering comparisons and thought that “Video for Window” would give me the Highest Quality AVI file so that i can import into ENCORE
    later to transcode and make DVD. Now reading this forum i see responses to several posts that need to render out from Vegas as MPEG-2 and now I’m all confused because when doing HD editing i recall that i have to render out as MPEG-2 also (for later import into ENCORE), SO what is the best? “Video for Window” or “MPEG-2?”
    Would someone give my the right answer Please.
    Thank you so much.
    Max
  • Jeremy Rasnic
    August 31, 2009 at 5:11 pm
    Hi Max,
    I do not use Encore so I don’t know how its encoding engine is tweaked to handle compression for DVDs. However, I do know that Vegas has a pretty good encoder that is tweakable and I would let it make the compliant files and then just open those in your DVD authoring program of choice.
    j razz
