Activity › Forums › Avid Media Composer › New to Avid – Couple Basic Questions
  • New to Avid – Couple Basic Questions
    Posted by Matthew Sonnenfeld on November 16, 2009 at 8:31 am
    Hi Everyone,
    So normally I edit with Final Cut Pro but I’m trying to get my feet wet in the Avid world. I bought Media Composer 3.5 over the summer with the student discount (thank god for it) and I haven’t had much of a reason to toy with it so I haven’t done much. I will be working with it though in December so I am trying my best to learn the program as well as I can in the next month.
    My two questions are these:
    1) How do I set up my Avid to use dual screen editing? That is, how would I use an HD monitor for viewing? (I am editing on a 15″ MacBook Pro Unibody from 2008 – With the ExpressCard 34 port and removable battery)
    2) How do I remove 3:2 pulldown from P2 DVCPRO HD footage? 24PA?
    Thanks a bundle!
    Matt
    Panasonic HPX170 P
    Unibody Macbook Pro 15 inch, 2.8 Ghz, 4GB RAM
    Final Cut Pro Studio 2
    Avid Media Composer
    The College of WIlliam and Mary
    Shane Ross replied 16 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    November 16, 2009 at 5:19 pm
    [Matthew Sonnenfeld] “1) How do I set up my Avid to use dual screen editing? That is, how would I use an HD monitor for viewing?”
    Well, you are a bit confused here. DUAL SCREEN EDITING means two WORKSPACE monitors. One for bins, one for the timeline. That is fairly easy as all you need to do is add a monitor to the system. You have a DVI port.
    As for an HD monitor for proper monitoring, you’ll need to get the MOJO DX for that. That is the only device that works with a laptop and Avid MC. Then you’ll need to get the monitor. This isn’t a cheap proposition. The MOJO runs $4000, and then there’s the cost of the monitor.
    [Matthew Sonnenfeld] “2) How do I remove 3:2 pulldown from P2 DVCPRO HD footage? 24PA?”
    I haven’t done that yet…GOOD QUESTION. I want to know too. but I am sure a search of the forum for that question will get results.
    Shane
  • Shane Ross
    November 16, 2009 at 5:23 pm
    AHHH…..Avid can’t do this internally. You need to get DV Films MXFX program to do it.
    https://community.avid.com/forums/t/70494.aspx
    Avid…you got SO MANY THINGS RIGHT…why can’t you remove pulldown? But then again, FCP doesn’t have native MXF support, nor import all that metadata without third party help…
    Shane
