Activity › Forums › Sony Cameras › New Pro Applications Update
Posted by Chris Babbitt on December 17, 2013 at 9:13 pmA new Pro Applications update 2010-02 just appeared in my software updates. Is this the same one that’s creating all the misery with XDDAM, or is this a fix?
Ian Cook replied 12 years, 9 months ago 2 Members · 3 Replies -
Ian Cook
December 17, 2013 at 9:23 pmThe issue is with Pro Apps update 1.03 and it only affects Snow Leopard users
Chris Babbitt
December 18, 2013 at 5:20 pmI am on Snow Leopard, so I just want to be sure of what I am doing before I install. I think this is an older update, but I recently re-installed Compressor from my FCP Studio 2 discs, so I think that might be why I am getting this update. Here is what it says:
Pro Applications Update 2010-02 adds compatibility for new camera formats, improves overall stability, and addresses a number of other minor issues. This update is recommended for all users of Final Cut Studio, Final Cut Server, and Logic Studio.
Issues addressed in this update include the following:
Final Cut Pro
• Real-time compatibility with Sony XDCAM HD422 720p24/p25/p30.
• Log and Transfer compatibility with Sony NXCAM SD.
• Control-G not closing the correct gap in the Timeline under the playhead.
• Closed captioning data is now preserved when outputting to AJA Io HD with Print to Tape/Video.
• Performance issue when importing AVCHD with LPCM audio.
• AVCHD thumbnail images in SD are now the correct 4:3 aspect ratio.
• XML export now retains the carriage return when working with text and third-party applications.
• Several memory fragmentation issues have been resolved.
• Localized versions of Final Cut Pro now recognize HDV devices that use the 1080i60/1080i50 FireWire Basic Easy Setups.
• Log and Transfer supports ingesting more than one format recorded to the same SD card.Motion
• Corrupted display of the camera controls with certain graphics processors.Compressor
• Adds a compression setting optimized for iPad and iPhone 4.Color
• Adds compatibility with XDCAM HD422 720p24/p25/p30.For more detailed information about the changes in an application, choose Release Notes from the application’s Help menu.
Is this going to be OK?
Ian Cook
December 18, 2013 at 5:23 pmthis is an old one with mostly FCP 7.0.3 elements. it should be safe but I can’t be 100% sure because they may have added something to it since it was first released. copy your QT library folder before you update. you can then revert back if necessary.
