Activity Forums Adobe After Effects New plugin
  • New plugin
    Posted by Mylenium on February 2, 2006 at 7:02 pm
    My esteemed friend Stefan Minning has just released his first plugin called Normality. It allows pseudo-3D image relighting based on normal maps. These normal maps can be created in almost every 3D program and I know that many of you use tools such as Lightwave and Cinema4D, so I thought you might be interested in it. Though obviously it won’t fix a bad render, it can help you adding some finesse to your stuff without always needing to re-render everything. Needless to say that it strengthens AE in the area of 3D integration. More advanced plugins for creating toon effects or using UV data from RPF files are in development (see [url]https://www.plausibleimpossible.de[/url]).
    Thanks for your attention
    Mylenium
    [Pour Myl
    Don Jaksa replied 20 years, 7 months ago 8 Members · 10 Replies
  • 10 Replies
  • Mylenium
    February 2, 2006 at 7:04 pm
    My esteemed friend Stefan Minning has just released his first plugin called Normality. It allows pseudo-3D image relighting based on normal maps. These normal maps can be created in almost every 3D program and I know that many of you use tools such as Lightwave and Cinema4D, so I thought you might be interested in it. Though obviously it won’t fix a bad render, it can help you adding some finesse to your stuff without always needing to re-render everything. Needless to say that it strengthens AE in the area of 3D integration. More advanced plugins for creating toon effects or using UV data from RPF files are in development (see https://www.plausibleimpossible.de).” target=”_blank”>https://www.plausibleimpossible.de”>https://www.plausibleimpossible.de).
    Mylenium
    [Pour Myl
  • Mylenium
    February 2, 2006 at 7:06 pm
    My esteemed friend Stefan Minning has just released his first plugin called Normality. It allows pseudo-3D image relighting based on normal maps. These normal maps can be created in almost every 3D program and I know that many of you use tools such as Lightwave and Cinema4D, so I thought you might be interested in it. Though obviously it won’t fix a bad render, it can help you adding some finesse to your stuff without always needing to re-render everything. Needless to say that it strengthens AE in the area of 3D integration. More advanced plugins for creating toon effects or using UV data from RPF files are in development (see https://www.plausibleimpossible.de ).
    Mylenium
    [Pour Myl
  • Spritemaster
    February 2, 2006 at 7:24 pm
    Thanks Mylenium, this looks amazing. Can’t wait to see Reality and Toxicity in action.
    AA
  • Nicholas Toth
    February 2, 2006 at 8:53 pm
    wow that actually sounds very handy…and its realtively inexpensive in comparison to ANY AE PLUGINS.
  • Alpay Kasal
    February 2, 2006 at 9:55 pm
    Looks awesome. Am I to understand that the plugin is also responsible for bringing a 3D object into the AE comp? or does a normals map simply appear to be 3D when loaded?
    Any idea on a timeline of when the anime/toon plugin is expected? That might prove to be very handy for me in a few months. i am going to start researching my options soon, I have to gather the technologies to easily create half-hour animated eps for show with an anime feel.
    thanks.
    Alpay Kasal
    Artist/Engineer
    https://www.NYCRenderfarm.com
  • Stefan Minning
    February 2, 2006 at 10:44 pm
    The plug-in itself doesn’t help you obtain the normal-map from a 3D program. With the number of programs on the market today, that simply isn’t feasible.
    However, it’s quite easy to get the normal maps yourself. Many programs like Cinema 4D for example actually have features to export them, in others like Maya and 3ds max it’s just a matter of selected a normal map shader and hitting render.
    Then all you need to do is import in AE and your ready to light!
    Cheers,
    Stefan Minning
    Tte Plausible Impossible
  • Christopher R. green
    February 3, 2006 at 4:12 am
    Pant pant pant.
    Cannot wait to mess with this …
  • Mike Clasby
    February 3, 2006 at 10:28 am
    This is probably a crazy question, but is there a way to generate a “normal map” for a 2D object? Probably not I guess. I’ve got some 2D objects (like Dan’s “Animating A Walk Cycle” characters) that need shading, and I’ve used the RE:Shade/shape demo, it works OK until you get places like the Dragon’s legs (on the website above), RE just works off the alpha and the legs would blend into the body, becoming one big lump.
    I guess I’m asking if I could somehow create a “Normal map” (Hey, colorama looks psychedelic too)for each of my 2D body parts.
  • Mylenium
    February 3, 2006 at 5:27 pm
    Normal maps are just RGB images where the three channels are used to store vector info of the surface normals (hence the name). The plugin itself doesn’t care how those maps were created, it will just look up the pixel values. So to some degree your idea might work by creating controlled shading using filters and then tinting it with Colorama. You shouldn’t expect miracles, though. The plugin won’t add a real 3rd dimension to your 2D footage, so it really comes down to how skillfully you can translate common realworld experience into the synthetic world. It will also be very difficult to control where the fake like hits. Since each of the specular/ diffuse shaded points is a result of combining all 3 channels, you will scratch your head more than once trying to figure out how to tweak the channels. I already thought about this myself and it might be helpful to create an expression driven template project for this of these days, but at the moment I simply don’t have the time. I wish you the best of luck with your experiments and let us know if you come up with something cool.
    Mylenium
    [Pour Myl
  • Don Jaksa
    February 4, 2006 at 12:37 am
    Can’t Wait for an OSX version!!
