Activity › Forums › AJA Video Systems › New Kona driver and ATTO
  • New Kona driver and ATTO
    Posted by Don Wilson on October 23, 2006 at 7:02 pm
    I’ve updated my UL5D driver from ATTO to allow for larger ram and loaded the new Kona 10/13 driver as well. Since then I’ve been experiencing random system freezes. Anyone have any experience with similar updates and issues?
    Don Wilson
    AmericanaMediaInc.com
    Jeremy Garchow replied 19 years, 11 months ago 6 Members · 24 Replies
  • 24 Replies
  • Jeremy Garchow
    October 23, 2006 at 7:28 pm
    I had some of those issues with the 3.1 driver when first installed. An uninstall, restart, delete the Kona Package in Library > Receipts, shut down & wait 10 seconds, Reinstall latest drivers, restart, fixed my problem.
    Are you still on the G5 in your profile?
    Jeremy
  • Mark Maness
    Try removing RAM. Have you tested to see if your RAM is good? Sounds like you might have a bad RAM module. Use Apple’s Hardware Test that came with your computer’s CD that contains OSX.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Don Wilson
    October 23, 2006 at 7:41 pm
    Jeremy,
    I will go and update my profile next but I have migrated two systems to the Mac Pros. Good call. I know we’d talked about Mac Pro issues recently. The RAM passes the hardware test as that was my first thought. When working properly the system really speeds up with the extra memory I must say. As well, I’m still have the annoying crackle in the audio and have to stop and start playback until it goes away.
    Don
  • Walter Biscardi
    October 23, 2006 at 7:48 pm
    [Don Wilson] “I will go and update my profile next but I have migrated two systems to the Mac Pros.”
    Pull RAM down to 2GB until ATTO updates their drivers.
    [Don Wilson] “As well, I’m still have the annoying crackle in the audio and have to stop and start playback until it goes away.”
    Yep, we’ve had that on all our Kona systems since V 2.0 of the Kona drivers came out. Can’t seem to track down where that comes from.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Jeremy Garchow
    October 23, 2006 at 7:50 pm
    How much RAM do you have installed and is it installed properly? There’s an issue with more than 2GBs of RAM and atto.
    Also, make sure you read this to see if your ram is in the MacPro correctly:
    https://docs.info.apple.com/article.html?artnum=304492
    Yes the crackle, what do you use for an audio d/a?
    Jeremy
  • Don Wilson
    October 23, 2006 at 7:53 pm
    This is the new ATTO driver as of Friday. I spoke with ATTO as well and supposedly there is no limit to the amount of ram anymore.
    Don
    Don Wilson
  • Don Wilson
    October 23, 2006 at 8:05 pm
    Jeremy,
    I could not really understand the chart. I have 2 1 gig sticks in riser 1 and 4 512 sticks in riser two. Melrose Mac said they’d exchange the 4 512s for 2 1 gigers if I need to. What do you think?
    Don
    Don Wilson
  • Mark Maness
    October 23, 2006 at 8:15 pm
    What version of the driver is it?
    Wayne Carey
    Schazam Productions
  • Jeremy Garchow
    October 23, 2006 at 8:39 pm
    According to that chart, you should have the two 1Gbs in Riser 1, two of the 512s in riser 2 then 2 of the 512s in Riser 1. In summary:
    Riser 1: 2-1GB sticks then 2-512 sticks.
    Riser 2: 2-512 sticks.
    If you swap the 4-512 sticks for 2-1Gb sticks, then put those in Riser 2.
    Confusing, but does this make sense?
    Jeremy
  • Jeremy Garchow
    October 23, 2006 at 8:41 pm
    On second look, I would definitely trade in your 4 512s for 2 1GB and then your riser pairs will match (2 in A, 2 in B)
    Jeremy
Page 1 of 3
