Activity Forums Apple Final Cut Pro Legacy New Install FCP 6.0.6 – No XDCAM 720P Easy Set Up???
  • New Install FCP 6.0.6 – No XDCAM 720P Easy Set Up???
    Posted by Kellen Dengler on September 28, 2009 at 8:30 pm
    This one is really weird to me so I am posting to a couple support locations in hopes of quick help:
    I recently did a fresh install of FCP 6.0.6 on my MacBook Pro running Leopard 10.5.8. I also installed the Sony XDCAM Drivers for using Sony SxS XDCAM Media via Sony EX3.
    For some reason when I go to Easy Setup in FCP menu there is no option to begin a project in 720P only the various frame rates for 1080P. What could be causing this and how do I get 720P project options?
    Rafael Amador replied 16 years, 11 months ago 3 Members · 5 Replies
  • Michael Gissing
    September 28, 2009 at 10:33 pm
    I thought that XDCam always shoots 1080 not 720. You could use Prores or DVCProHD for your sequence
  • Kellen Dengler
    September 29, 2009 at 12:23 am
    No the EX1 & EX3 can shoot in 720P. This is the weirdest thing because on my Mac Pro with the same OSX and FCP I have the option in Easy Set Up to create a project in Sony XDCAM 720P or 1080.
    Is there maybe a missing driver or something I could have missed?
  • Michael Gissing
    September 29, 2009 at 12:31 am
    Try dragging a shot into a 1080 sequence and see if FCP will change the sequence settings to the correct option.
    Even though you can’t see it in Easy Setups, XDCam 720 might be available.
  • Kellen Dengler
    September 29, 2009 at 1:35 am
    Yeah this works. It prompts me to change the timeline settings to match the source footage settings. I just find it weird that it doesn’t offer 720P as an easy set up…
  • Rafael Amador
    September 29, 2009 at 11:56 am
    Hi Kellen,
    I have FC Easy Setups in three different folders.
    – Applications> FC Easy Setups
    – Library> Applications Supports> FC System Support> Custom Settings
    – AJA preferences
    – Sheers folder.
    You may have also Easy Setups in Users~Library>Preferences> Final Cut Users settings.
    I have in a coupe of places more;
    A mess, don’t you think so?
    FC have now a kind of Easy Setups manager.
    Open the Easy Setups window (Ctrl-Q) and in Formats check XDCAM HD you may be lucky.
    Cheers,
    rafael
    http://www.nagavideo.com
