Activity Forums Apple Final Cut Pro Legacy New iMac 13,1 with OSX 10.9.2 not launching FCP7 after clean install [WITH LOG REPORT]
  • New iMac 13,1 with OSX 10.9.2 not launching FCP7 after clean install [WITH LOG REPORT]
    Posted by Jon Nicholas on March 27, 2014 at 3:21 pm
    I work at a university, and unfortunately I have no control over which computers are purchased for my department(don’t get me started…). They upgraded our older iMacs to a newer 13,1 iMac with 10.9.2 installed.
    I had the fun of buying an external disc drive, just so I could install FCP7 and the rest of the studio package.
    After the fresh install, I launched FCP7 and after pressing the “Register Later” button, it loads everything up to the Master Templates and then the window disappears, and the application closes. No warning, or window. I have rebooted, shut down, cleaned the preferences. Nothing. Here is a crash report:
    Process: Final Cut Pro [1840]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: ???
    Build Info: FCPApp-1008261348~8
    Code Type: X86 (Native)
    Parent Process: launchd [159]
    Responsible: Final Cut Pro [1840]
    User ID: 502
    Date/Time: 2014-03-23 13:45:33.666 -0400
    OS Version: Mac OS X 10.9.2 (13C64)
    Report Version: 11
    Anonymous UUID: 3F948FEB-4270-2475-1234-25AC3A84906F
    Sleep/Wake UUID: 1D912BC0-A3A3-4145-A827-0B3B4B0E7ED7
    Crashed Thread: 0
    Exception Type: EXC_BREAKPOINT (SIGTRAP)
    Exception Codes: 0x0000000000000002, 0x0000000000000000
    Application Specific Information:
    dyld: launch, loading dependent libraries
    Dyld Error Message:
    Library not loaded: /Library/Application Support/ProApps/SharedA/Frameworks/ProFX.framework/Versions/A/ProFX
    Referenced from: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Reason: image not found
    Binary Images:
    0x8fe99000 – 0x8fecb417 dyld (239.4) <2E655535-479B-3E48-ADD3-6278819CA38A> /usr/lib/dyld
    0x906de000 – 0x906defff com.apple.Carbon (154 – 157) <33457512-4EA2-373B-BB04-A6A7B6D4E54A> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x90bed000 – 0x90c62ffb com.apple.framework.IOKit (2.0.1 – 907.90.2) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x9439a000 – 0x9439affd com.apple.audio.units.AudioUnit (1.10 – 1.10) <85316395-817E-342D-8F41-88838EC6FB63> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x944f2000 – 0x9469efff com.apple.QuartzCore (1.8 – 332.3) <00167BF7-E3C4-3AA7-8DA0-466BD4175350> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x946ce000 – 0x946d5ffe com.apple.agl (3.2.3 – AGL-3.2.3) <665F1D85-FC12-3782-9A2F-9523EE4C9E8E> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x95b45000 – 0x95b45fff com.apple.quartzframework (1.5 – 1.5) <95E39CD5-E118-323F-9F0F-EE605EC029CF> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x95b46000 – 0x95b54ff3 com.apple.opengl (9.6.0 – 9.6.0) <63941A8D-AACC-3C71-BE8C-4DAA913A1439> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x973d7000 – 0x9757f4af libobjc.A.dylib (551.1) <18361D2F-0405-39B0-8354-2D865703118D> /usr/lib/libobjc.A.dylib
    0x981b8000 – 0x98434fe7 com.apple.QuickTime (7.7.3 – 2826.17) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x98463000 – 0x98464fff libSystem.B.dylib (1197.1.1) <5A9C548E-A852-35B3-B9AB-DF658EF75242> /usr/lib/libSystem.B.dylib
    0x99e9b000 – 0x99ef0ff7 com.apple.audio.CoreAudio (4.2.0 – 4.2.0) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x9a98a000 – 0x9a9f3fff com.apple.SystemConfiguration (1.13 – 1.13) <144317BE-7AE5-3B8D-90CD-62DCDE9399E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x9aa38000 – 0x9aca6ff6 com.apple.security (7.0 – 55471.14) <7915499B-66CF-39FE-B53C-A11C7775314D> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x9acff000 – 0x9acfffff com.apple.Accelerate (1.9 – Accelerate 1.9) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x9b2de000 – 0x9b32fff1 libstdc++.6.dylib (60) <354F284B-2343-3810-9CA2-E28038824F6E> /usr/lib/libstdc++.6.dylib
    0x9b417000 – 0x9b619fff com.apple.CoreFoundation (6.9 – 855.14) <756998B3-F507-3474-AFB2-769FC9CE5263> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x9b8ea000 – 0x9b8eafff com.apple.Cocoa (6.8 – 20) <63DA3D59-5D81-3340-A985-A11CE4A3E83F> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    Please help!
    David Gallessich replied 12 years, 5 months ago 3 Members · 4 Replies
  • Massimo Alberto croce
    March 27, 2014 at 10:45 pm
    Mavericks is not supported, partition your disk with and install mac os 10.8.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • David Gallessich
    March 28, 2014 at 2:53 am
    I’ve been running fcp7 suite on the latest 27″ iMac since January (first on 10.9.1, now on 10.9.2).
    I believe there are several others on this forum doing the same, so it should be possible for you also.
    Two things that might help:
    – You’ll need the latest proapps upgrade from apple, and Software Update should detect this.
    – You may also need to install Perian tools for Quicktime. (It’s end-of-line, just like FCP7.)
    I’ve experienced some transient video/audio latency issues in viewer window: annoying, not quite catastrophic. Biggest issue I’ve seen on the iMac is with external disks dismounting.
    Please keep us posted on what you learn!
    dg
  • Jon Nicholas
    March 28, 2014 at 2:14 pm
    Thanks for the tips! I made sure to update my pro apps, and I installed Perian, but I’m still getting the same issue. I think I’m just going to have to partition and load 10.8. …
  • David Gallessich
    March 28, 2014 at 7:58 pm
    OK, here’s another possibility …
    I did a quick googling of “A/ProFX” and came up with this thread (see below, at bottom).
    This was posted in 2010, and involved FinalCut Express. But the problem seems very similar, if not identical.
    Because I did NOT do the step-by-step install of every final cut (from FCS to FCS HD), I don’t have LiveType loaded (and I didn’t see this problem).
    Based on this discussion thread, I’m wondering if LiveType is an issue here.
    So, it might be worth a try to install w/o LiveType, or perhaps try the method on this older thread.
    (Also – “FCS REMOVER” from Digital Rebellion is a free app — might be handy in your situation.)
    Here’s that discussion link: https://discussions.apple.com/message/10842881#10842881
    Text of the final post in the thread:
    This solution worked for me:
    I installed FCE4 onto a brand new mini (10.6.2) and had the “/Library/Frameworks/ProFX.framework/Versions/A/ProFX” error.
    After an hour of going though the results of googling “/Library/Frameworks/ProFX.framework/Versions/A/ProFX” I found this page:
    https://blogs.oreilly.com/aperture/2008/03/apples-pluginmanager-173-utili.html.
    And installing this fixed the problem. Now FCE4 opens as it should
    https://www.apple.com/support/downloads/pluginmanager173.html
