Activity › Forums › Apple Final Cut Pro Legacy › New i7 w/ FCP 6.0 not recognizing Sony Capture Deck
  • New i7 w/ FCP 6.0 not recognizing Sony Capture Deck
    Posted by Jeremy Elbert on December 25, 2010 at 11:42 pm
    I just upgraded to a 2.93 GHz Core i7. We have FCP 6.0 and it now won’t recognize my Sony HVR-M15AU. This machine has the new firewire but beyond that what would be different. Any thoughts are greatly appreciated.
    je
    Craig Alan replied 15 years, 9 months ago 3 Members · 5 Replies
  • Walter Biscardi
    December 26, 2010 at 1:50 am
    You didn’t connect the machine to the iMac while it was turned on, did you? That can fry the Sony VTR Firewire port and / or the iMac Firewire port.
    Beyond that, if you’re trying to capture HDV, be sure you’re in an HDV Easy Setup and make sure the Sony deck is set for HDV playback via firewire.
    If you’re trying to capture DV, then you have to ensure you have the Firewire set to downconvert to DVCAM via Firewire for FCP to properly recognize the deck.
    When we run our Sony HDV decks via the AJA Kona boards, we have to set the Firewire output to downconvert to DVCAM for deck control.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
    Blog Twitter Facebook
  • Jeremy Elbert
    December 26, 2010 at 1:53 am
    Actually I did. Unfortunately I was not aware of that issue, as this is not the first time I have connected a deck to an iMac. This is a secondary machine and the first one I’m positive i connected them will on. Do you have thoughts on how I would know if something was fried in your words. 🙂
  • Jeremy Elbert
    December 26, 2010 at 2:15 am
    Additional info……….I just hooked the deck up to 1 year old iMac and all works fine. So perhaps bad firewire or something with the new iMac…?
  • Walter Biscardi
    December 26, 2010 at 1:24 pm
    [Jeremy Elbert] “Actually I did. Unfortunately I was not aware of that issue, as this is not the first time I have connected a deck to an iMac. This is a secondary machine and the first one I’m positive i connected them will on. Do you have thoughts on how I would know if something was fried in your words. :)”
    Any firewire device should be turned off before it is connected to a computer to prevent an electric surge that has been known to fry firewire ports.
    Does any other firewire device work when connected to the same iMac? If so, then you most likely have your VTR or FCP Easy Setup set incorrectly to control the VTR. We have three of the M15U’s here and always have the iLink sent to downconvert to DVCAM since we capture via the component outputs to our Kona cards. We just use the Firewire for device control.
  • Craig Alan
    December 26, 2010 at 4:19 pm
    so try a different firewire device like a ext. HD and see.
    OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz
    ; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP certified; write professionally for a variety of media; teach video production in L.A.
