  • Posted by João Lisboa on September 27, 2020 at 12:10 am
    Hi all,
    I’ve been out of business for, quite, a while so do not send me stones, pls.
    My last Workstation had a Targa 3K…
    I want to do a couple of personal projects and decided to build a WS again.
    My source material will be:
    – 60% video files from a Nikon D800
    – 40% from Beta SD, DigiBeta and HDV archive.
    The projects will be edited on 1920*1080 and exported for DCP (DCP-o-matic), Blu-ray, and a PAL version for DVD.
    I want to have 2 large “menu” monitors in 4K each (for software) and a “Video Out” for a Television and/or a projector (HDMI in both cases).
    5.1 audio is also need.
    What should I connect to an NVidia board and what to connect to an I/O board.
    Advice on an I/O is welcome.
    Thank you,
    Eric Santiago replied 6 years ago 3 Members · 3 Replies
  • João Lisboa
    September 27, 2020 at 9:29 pm
    Maybe my post was confuse.
    My main question is:
    Where should I get the main “Video Out” for a Television and/or a projector,
    from the capture card or from the Nvidia?
    I will be using only 2 monitors for menus and the GPU will have 3 or 4 HDMI ports.
    And the 5.1 audio, from a dedicated audio board?
    Any advice, pls
  • Michael Gissing
    September 27, 2020 at 11:24 pm
    What editing software do you want to use? If cross platform then I would be using PC hardware with a Decklink card. If you want to use FCPX, then you must use Apple hardware. Your software choice determines your hardware options
  • Eric Santiago
    September 28, 2020 at 1:24 pm
    You can use cross-platform gear on the Mac side as well.
    There are high/low-end options.
    I use a BMD UltraStudio 4K for both Mac/PC at home and Avid Artist IO which is basically a BMD UltraStudio 4K Extreme.
    In the past, BMD Decklink PCI cards and yes for both PC and Mac.
    I use all of the above with REDCINE-X, FCP/FCPX, Premiere/AE, and Avid.
