Activity › Forums › Apple Final Cut Pro Legacy › New Hard Drive Recommendation for Firewire 800 port
  • New Hard Drive Recommendation for Firewire 800 port
    Posted by Zack Mulvaney on November 25, 2011 at 5:49 am
    I’ve been having some problems with my g-drive, so i’m in the market for a new external hard drive for editing (1TB+). The fastest port my imac has is firewire 800. Any recommendations? Newegg seems pretty thin on options for firewire 800 hard drives, so the help in finding a good option is much appreciated.
    Also, I’m just assuming I should go with a firewire 800 hard drive since that’s my fastest port — if anyone disagrees on my amateur thinking here, please do enlighten me.
    Bret Williams replied 14 years, 10 months ago 4 Members · 5 Replies
  • Adam Taylor
    November 25, 2011 at 9:19 am
    I have a Glyph Portagig62 – which is very good. Its a small portable raid made with 2x 2.5″ drives, and it is firewire 800 bus powered.
    Its been extremely reliable (i got it to replace a g-raid mini which died after only three power ups!).
    I’m very happy with the Glyph.
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
  • Zack Mulvaney
    November 25, 2011 at 9:22 am
    Thanks for the rec. I’m not sure I need raid, and obviously I’d like to avoid the price tag of raid if possible. Any recs on non-raid?
  • Brian Vedholm
    November 25, 2011 at 9:37 am
    I use CalDigit VR connected to my IMac with firewire 800. Works for me. Never had any problems.
    https://www.stjernholm-media-proshop.dk/product.asp?product=6150
  • Adam Taylor
    November 25, 2011 at 10:25 am
    it only costs £180 (not expensive in my book)- and you were asking about firewire800 because its your fastest port – and Raid is typically faster than a single drive.
    Raid has two benefits with a drive like this- you can set it one way and get increased speed or set it for security by duplicating the data to both drives.
    Adam Taylor
    Oldham, UK
  • Bret Williams
    November 25, 2011 at 10:17 pm
    There is no performance gain with a raid over FW800. A single firewire 800 drive maxes out the data capacity of FW800. These G-Raids and such usually have an esata port, of which you will gain a 30% performance jump just for eSATA, but if you raid it AND use a compatible eSATA card (usually $200+, not the $50 ones) then you can quadruple or more the performance of the drive vs. hooking it up FW800.
