Activity › Forums › Creative Community Conversations › New FCPX confirmed for December
Jeremy Garchow replied 12 years, 10 months ago 29 Members · 87 Replies
Mitch Ives
October 23, 2013 at 2:11 amHerb, your point wasn’t lost on everybody… I got it.
Mitch Ives
Insight Productions Corp.“Criticism may not be agreeable, but it is necessary. It fulfills the same function as pain in the human body. It calls attention to an unhealthy state of things.” – Winston Churchill
Oliver Peters
October 23, 2013 at 2:13 amSomebody in another thread posted the UI for the new iMovie as a clue to what FCP X 10.1 might look like. Well, actually I think this is it. Posted by Wired. Note the UI here on a Sharp 4K monitor and the clip edges are no longer rounded. Just a guess, of course.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Mitch Ives
October 23, 2013 at 2:15 am[Aindreas Gallagher] “I mean, I guess there’s nothing wrong, per se, with making noises like a tea party activist on behalf of those currently executing professional work through FCPX. You’d have to think FCPX has quite a few moderates these days though.”
As a Brit, I can see why the whole “Tea Party Activist” thing has you a bit anxiety ridden. For the rest of us members of the colonies, that’s a term of endearment…
Mitch Ives
Andy Neil
October 23, 2013 at 2:26 amIf that’s it, it doesn’t look that much different. Aside from tweaking the colors and clip representations, it looks pretty close to the same.
Andy
https://www.timesavertutorials.com
Mark Raudonis
October 23, 2013 at 2:53 amRE: 4K
There are some surprising uses for 4K that you may not have considered. Even in reality TV!
Example: Let’s say you have an interview with TWO people on camera. One 4K camera can give you THREE camera angles: WS, CU left, CU RT. With a loosely framed “two shot” you simply “punch in” on the CU as needed. 4K can support a 300 per cent blow up for a CU and still have the same resolution as HD. In other words, you can get three camera coverage out of a single media file. That’s pretty efficient.
We’re already doing this.
4K… consider the possibilities!
mark
Jeremy Garchow
October 23, 2013 at 2:59 amThat’s exactly my use for 4k as well.
One camera, multiple hi resolution crops.
Andrew Kimery
October 23, 2013 at 3:06 amMark,
All the reality shows I’ve worked on cut in SD for storage reasons. How do you fold the 4K into your offline/online workflow?
Chris Harlan
October 23, 2013 at 3:11 amBack in the SD world, I used to do that all the time with HD.
Andrew Kimery
October 23, 2013 at 3:46 am[Chris Harlan] “Back in the SD world, I used to do that all the time with HD.”
On shows with thousands of hours of footage there aren’t many other options.
Seems the online/offline workflow just won’t die. Once tech gets fast enough and cheap enough to handle a current format something bigger comes down the line and makes all our gear look old and slow again. lol
