Activity › Forums › AJA Video Systems › New driver changed my Easy Setups
Posted by Mark Maness on August 31, 2006 at 6:14 pmIt’s nothing we can do and its easily fixed but when I installed the new driver, it changed my 525i29.97 Easy Setups to 23.98. Strange? Yeah… But it is easily changed when you edit the Capture Setups.
Just wanted to make everybody aware… It could just be me but I’m sure somebody else will see this.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.comMark Maness replied 20 years ago 3 Members · 6 Replies -
Gary Adcock
September 1, 2006 at 12:18 pm[Wayne Carey] “It’s nothing we can do and its easily fixed but when I installed the new driver, it changed my 525i29.97 Easy Setups to 23.98. Strange? Yeah… But it is easily changed when you edit the Capture Setups.”
Wayne
Make sure you tell AJA support so they can track it in case it is not only you.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Mark Maness
September 1, 2006 at 1:24 pm[gary adcock] “Make sure you tell AJA support so they can track it in case it is not only you.”
Oh, I have… I just wanted to see if anyone else here has seen this. The more that seen an error, the easier it is to fix.
Wayne Carey
Schazam Productions
http://www.schazamproductions.com -
Michael Rothenberg
September 5, 2006 at 5:41 pmMy Easy Setups seem to be corrupted as well. I no longer can use the 8 bit to DV Easy Setup, even if I manually go in and correct the settings.
I see no video in Capture mode – which is odd because if I switch over to the 8 bit Uncompressed Easy Setup everything is fine.
When I edit the Capture settings to [Kona 8-bit digitizer, 29.97, NTSC DVCPRO-DV codec, etc.] I get a strange hash and still no Capturing.
This is very frustrating as this has been my default workflow for large projects – offline in DV, then online in SD or DVCPRO-HD.
Thanks for any advice.
Mike
Michael Rothenberg
Peak Productions -
Mark Maness
September 5, 2006 at 8:02 pmYou’ll have to change your capture settings from 23.98 to 29.97. This is what the driver has changed. As for the DV issue, there is a support doc at Apple’s tech support site that tells you how to reset your Quicktime and re-install the latest Quicktime.
Wayne Carey
Schazam Productions
Michael Rothenberg
September 5, 2006 at 10:36 pmTurns out it’s probably a bad card. (Uncompressed 8 bit works fine.) Kona sending me a new one overnight – great support! Will report back if it turns out to be something else. Thanks.
Michael Rothenberg
Peak Productions -
Mark Maness
September 6, 2006 at 1:37 pmWell…. That will do it! I’ve just gone thru a problem with them also and I hope to get my replacement card in a couple of days. My problem was relating to the fact that the serial port rarely worked at all. Ayways… It’s nice to know that AJA is so willing to help out its customers. THANKS AJA!
Wayne Carey
Schazam Productions
