Activity Forums Adobe Premiere Pro New computer
  • New computer
    Posted by Nick Leigh on October 28, 2010 at 1:22 pm
    I am just looking for a little help as I am buying a new computer. I will only be editing some hockey games about 10 times a year. I am wondering if a computer with these specs will work ok for me:
    Processor: AMD Phenom II X4 955(3.2GHz)
    Processor Main Features: 64 bit Quad-Core Processor
    Cache Per Processor 4 x 512KB L2 Cache
    Memory: 4GB (2x2GB) DDR3 1333
    Hard Drive: 500GB SATA-II 3.0Gb/s 7200RPM HDD
    Optical Drive: 1 24X DVD±R/±RW Dual Layer Drive
    Graphics: NVIDIA GeForce 9800GT 1GB PCI Express Video Card
    Audio Sound card: Integrated
    Power Supply: 700W
    Operating System: Windows 7 Home Premium 64-Bit
    Chipset: AMD 770 CPU
    CPU Type: Phenom II X4
    CPU Speed: 955(3.2GHz)
    L2 Cache Per CPU: 4 x 512KB
    L3 Cache Per CPU: 6MB
    CPU Socket Type: AM3
    GPU/VPU Type: NVIDIA GeForce 9800 GT
    Graphics Interface: PCI Express 2.0 x16
    Memory Capacity: 4GB DDR3
    Memory Speed: DDR3 1333
    Form Factor: DIMM 240-pin
    Memory Spec: 2GB x 2
    Memory Slot: (Total) 4
    Memory Slot (Available)
    HDD Interface: SATA II
    Optical Drive Type: DVD±RW
    Optical Drive Spec: 24X DVD±R/±RW Dual Layer Drive Audio
    Audio Chipset: Integrated
    LAN Chipset: Integrated
    LAN Speed: 10/100/1000Mbps
    Front USB: 2
    Front eSATA: 1
    Front Audio Ports: 2
    PS/2: 2
    Video Ports: 1 VGA, 1 DVI, 1 HDMI
    Rear USB: 6 x USB 2.0, 2 x USB 3.0
    Rear IEEE 1394: 2
    RJ45: 1 port
    Rear Audio Ports: 6 ports
    S/P DIF: 2 port
    I have a 1TB drive that I will add when I get it but I’m looking for some help so I know that a PC like this will work well for Adobe Creative Suite 5 Production Premium. Also I am just looking for some suggestions on whether or not I should upgrade certain features that would benefit the editing process.
    This computer will basically only be used for editing so I don’t have to worry about rendering taking awhile it that is the case. It will just sit in my office so rendering time isn’t a huge factor for me.
    Thanks for any help you provide.
    Nick
    Nick Leigh replied 15 years, 10 months ago 2 Members · 4 Replies
  • Brian Louis
    October 28, 2010 at 8:42 pm
    I’d get at least 8gigs of memory, and I’d loose the 9800gt as its getting long in tooth, and get something with more cuda cores like a Fermi 470 which also has faster video ram(DDR5)
  • Nick Leigh
    November 1, 2010 at 2:48 pm
    I am now going to build a custom computer from scratch. I am wondering a couple things before I choose my specs…
    Will I see a big difference between the AMD Phenom II 3.2 GHz X6 and X4?
    I would like to buy a 150GB 10000RPM Hard drive as my system drive and then 2 1TB hard drives set up with raid 0, will that be sufficient? Or will I not see a difference if I go without the 10K RPM drive?
    I will be installed 8GB of ram (2 x 4GB) with the plan to add more if needed.
    On the adobe site the say to use GeForce GTX 470 or the 285 but will the GTX 460 work? Or will I see a big difference using the 470 or 285?
    Thanks for any help you can give me.
    Nick
  • Brian Louis
    November 2, 2010 at 2:08 am
    [Nick Leigh] “Will I see a big difference between the AMD Phenom II 3.2 GHz X6 and X4?”
    Particularly with rendering.
    [Nick Leigh] ” will I not see a difference if I go without the 10K RPM drive?”
    The 10k drive will load the system and apps fast, once loaded into memory it doesn’t matter, also will speed up virtual memory but not by much, if there is enough ram it doesn’t matter too much.
    [Nick Leigh] “but will the GTX 460 work? Or will I see a big difference using the 470 or 285?”
    If you use the hack: https://www.studio1productions.com/Articles/PremiereCS5.htm4
    just be sure you have good cooling, there are a few dual fan cards, I use the hack with a GTX260 and have compared it with a quadro 3800 and also a 465, and the only one that made a difference was the 465 and that was because of the DDR5 which the 460 has, read the article, also till they are using all the cores spending money on high end card for a editor that basically uses 100cores and the rest for the card mostly for display is iffy
  • Nick Leigh
    November 2, 2010 at 4:41 pm
    Hey Brian,
    Thanks for your help. I have just purchased the following from Newegg.com today.
    Processor: AMD Phenom II X6 1090T(3.2GHz)
    Processor Main Features: 64 bit Six-Core Processor
    Cache Per Processor 6 x 512KB L2 Cache
    Memory: 8GB (2x4GB) DDR3 1333
    System Drive: 60GB OCZ Agility 2 Internal SSD
    Hard Drive: 2 x 1TB SATA 6.0Gb/s 7200RPM HDD in Raid 0
    Optical Drive: LG 10x Blu-ray Burner SATA
    Graphics: Palit GeForce GTX 470(Fermi) 1.25GB PCI Express
    Power Supply: 650W
    Motherboard: ASUS M4A89GTD PRO
    Chipset: AMD 890GX
    CPU Type: Phenom II X6
    CPU Speed: 3.2GHz
    L2 Cache Per CPU: 6 x 512KB
    Memory Capacity: 8GB DDR3
    Memory Spec: 4GB x 2
    Memory Slot Available: 4
    HDD Interface: SATA 6.0/Gb/s && SATA 3.0/Gb/s
    Front USB: 2
    Front IEEE 1394: 1
    Video Ports: 2 DVI, 1 HDMI
    Rear IEEE 1394: 1
    S/P DIF: 2 port
    So I should have the new computer built by the weekend with windows 7 installed. Can’t wait to get CS5 production installed after that.
    Nick
