Activity Forums VEGAS Pro new build of Pro 11 released
  • new build of Pro 11 released
    Posted by Mike Kujbida on February 28, 2012 at 11:19 pm
    https://www.sonycreativesoftware.com/download/updates/vegaspro
    Notable fixes/changes in version 11.0 (Build 594/595)
    Improved support for the Sony XDCAM Professional Media Station (XDS) devices.
    Added the ability to render 28 Mbps constant bit rate MainConcept AVC format.
    Added the ability to drag FX packages to video track headers.
    Made double-clicking the horizontal scrollbar in the effect property page zoom out as in the main timeline.
    Fixed incorrect output that could occur when using GPU-accelerated Pan/Crop with rotation on large still images.
    Fixed incorrect output for Clock Wipe when in 32-bit floating-point video mode without GPU acceleration.
    Fixed incorrect alpha channel for Glow when running without GPU acceleration.
    Fixed incorrect output for Fill Light when in 32-bit floating point video mode without GPU acceleration.
    Fixed an issue that prevented HDV print to tape from functioning.
    Fixed an issue that prevented rendered HDV from being used as smart render source.
    Fixed an issue that could prevent rendering to VCD format using MainConcept MPEG-1 format.
    Fixed an issue that could prevent the Sony AVC format from rendering 5.1 surround audio.
    Fixed an issue that could prevent certain QuickTime files from displaying on an external monitor during Trimmer playback.
    Fixed the ability to render to QuickTime format using the MPEG-4 Low Complexity AAC audio codec.
    Fixed an instability that could occur when using 10-bit uncompressed YUV sources with GPU-accelerated video processing on some NVIDIA GPUs.
    Fixed an issue that could cause jumping in stabilized media if the project being loaded used a different frame rate than the previous project.
    Fixed an issue that could cause an FX automation envelope to control the wrong effect when working with plug-ins in the Mixing Console.
    Fixed the ability to set a custom metronome sound.
    Fixed pixel aspect ratio handling with the GPU-accelerated Linear Blur effect.
    Fixed alpha-channel handling in the GPU-accelerated Levels effect.
    Fixed alpha channel handling in the GPU-accelerated HSL Adjust effect.
    Fixed the text background for the GPU-accelerated Timecode to use solid black instead of transparent alpha.
    Fixed an issue that could cause the GPU-accelerated White Balance effect to create colors slightly off.
    Fixed a crash that could occur when using certain third-party compositor plug-ins if there was an audio track directly below the video track with the compositor.
    Fixed the default preset for the Timecode effect to be lower-right.
    Fixed crashes that could occur in the Titles & Text generator.
    GPU-accelerated Cookie Cutter and Page Loop are causing issues with the latest AMD OpenCL drivers (Catalyst 11.12 and 12.1) so we are no longer processing these with the GPU on that platform. We will restore these to use GPU processing after the driver is fixed.
    Steve Rhoden replied 14 years, 6 months ago 5 Members · 5 Replies
  • John Bean
    February 29, 2012 at 12:51 am
    Anyone else having problems with the new build?
    After install of the update, Vegas no longer runs. Click Vegas to run. But nothing happens. It seems like it just crashes but there are no error messages.
  • John Rofrano
    February 29, 2012 at 1:56 am
    It’s working great for me. I just ran through a 1 hour dry run of the webinar I’m going to give on Thursday for Boris FX and Vegas Pro 11.0 didn’t hickup once. It was steady as a rock and I was doing some pretty intense stuff with Boris Continuum Complete 8 and Boris RED 5.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Bean
    February 29, 2012 at 2:11 am
    I got it working for me now.
    I’m not sure what did it exactly.
    I was running build 521 previously and the new build 595 didn’t work on an update install.
    So I uninstalled everything, including my trial extensions of Vegasaur and VASST.
    Then, I did a clean install of build 595. Still no go.
    Then I did a clean re-installed of build 425. Then upgraded to build 595 from that version. And voila! Build 595 now works!
    Yeah, Windows knows magic sometimes.
  • Carl Alessi
    February 29, 2012 at 6:46 pm
    …and ironically, I just experienced my first crash with the new 64 bit build. I was simply running some m2ts raw footage on the timeline, and it stopped cold. Perhaps I should have rebooted the machine after the installation.
  • Steve Rhoden
    March 1, 2012 at 1:16 pm
    Having it running, but im still mostly using Vegas 10.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
