Activity › Forums › AJA Video Systems › *NEW* AJA Io HD v5.1 software available now
  • *NEW* AJA Io HD v5.1 software available now
    Posted by Aja Sales department on January 24, 2008 at 11:38 pm
    Hello,
    Available today at the Support section of our website is the new version 5.1 software Io HD (with new KONA software available as well, details on the KONA Cow page).
    *Important Io HD Note—Please Read*
    The software version number of the Io HD release has been changed to “5.1” to better communicate its parity with the KONA software releases issued now and in the future. Both product lines have similar underlying software and many features will often be updated at the same time in the future.
    *Io HD New Features*
    – User can now output either DVI or HDMI protocol on the HDMI output. (Note: output from the HDMI connector requires use of an HDMI to DVI cable adapter.)
    *Io HD Resolved Issues and Improvements*
    – Edit to tape frame accuracy improved in all interlaced formats.
    – Improved 10-bit RGB display operation in Motion and After Effects.
    – Saving Io HD Control Panel presets no longer requires Administrator privileges.
    – Fixed a problem that could cause the Io HD to get out of sync when switching between Final Cut and Motion.
    Io HD v5.1 software can be found here:
    https://www.aja.com/html/support_Io_swd.html
    Please thoroughly read the Release Notes and all information pertaining to the installation and use of the Io HD v5.1 software.
    As always, feel free to contact us with any additional questions.
    Thank you,
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
    Carsten Orlt replied 18 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Carsten Orlt
    January 25, 2008 at 12:20 am
    does this mean I can now get 1 to 1 pixel mapping via DVI to a Dell or Apple (or whatever) 1920*1200 monitor?
    Carsten
  • Gary Adcock
    January 25, 2008 at 1:52 am
    [Carsten Orlt] “does this mean I can now get 1 to 1 pixel mapping via DVI to a Dell or Apple (or whatever) 1920*1200 monitor?”
    if you own a Kona or Io Product with DVI on it
    yes it will.
    < since no Kona or Io products support DVI - this reply is meant as a joke>>>
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Carsten Orlt
    January 25, 2008 at 4:09 am
    well then read the ioHD release note again!
    and this is not ment as a joke 🙂
    Carsten
  • Gary Adcock
    January 25, 2008 at 4:20 am
    [Carsten Orlt] “then read the ioHD release note again! “
    you got me….
    I will find out.
    gary adcock
    Studio37
  • Carsten Orlt
    January 25, 2008 at 4:29 am
    no worries Gary 🙂
    would be great because I can’t test it as I don’t have the monitor to connect.
    But it would solve my HD monitoring problem.
    Color via SD and resolution via DVI 🙂
    Cheers
    Carsten
    Carsten
  • Gary Adcock
    January 25, 2008 at 5:00 pm
    Ok
    here is the scoop.
    the DVI > HDMI conforms to the SMPTE video output standard so that video being output matches the frame buffer of the IoHD.
    So the actual pixel count conforms to the video playbacks frame size where 1080 is only 1080, 720 is only 720 and SD is only SD (be it PAL or NTSC)
    There is NO scaling, so sending SD out the HDMI may not work on some displays, and 24p material is not always supported for direct output (this is an HDMI limitation on many displays)
    can I wash the egg off my face now?
    ga
    gary adcock
    Studio37
  • Carsten Orlt
    January 25, 2008 at 9:47 pm
    ok then, go and wash your face 🙂
    Thanks Gary!
    Cheers
    Carsten
