Activity Forums AJA Video Systems New Aggressive Cache in recent AJA Kona drivers enhances playback performance
  • New Aggressive Cache in recent AJA Kona drivers enhances playback performance
    Posted by Tom Daigon on November 12, 2011 at 3:13 pm
    I got the green light from the nice AJA folks to share some information that could be helpful to Mac users of Adobe CS5.5 Premiere Pro.. For anyone who has updated AJA drivers that might still be having some playback issues with their Kona output with certain formats, try this…. Right click on your sequence to open up the Sequence Settings window. Then click on Playback Setting to open that window. At the bottom right check Aggressive Cache. Then playback your sequence while watching the external monitor fed by the Kona.I found that it can really help things out. It is documented in the new release notes and manual.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
    Tom Daigon replied 14 years, 10 months ago 4 Members · 12 Replies
  • 12 Replies
  • Jeremy Garchow
    November 14, 2011 at 4:53 am
    [Tom Daigon] “Aggressive Cache”
    This should be the theme of NAB 2012.
  • Tom Daigon
    November 14, 2011 at 4:56 am
    I know its late and I havent eaten but…I dont get it. 😀
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Jeremy Garchow
    November 14, 2011 at 3:28 pm
    I was going for the double entendre sense of the word.
    You had to be there, I guess.
  • Shane Ross
    November 14, 2011 at 5:55 pm
    I don’t get it either…sorry.
    BUT, I did get this to work. Smooth playback on Canvas, and Viewer export to external monitor too. Leave it up to AJA to be the first to solve this.
    Shane
  • Tom Daigon
    November 14, 2011 at 10:12 pm
    Glad things are working for you Shane.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Josh Pappas
    November 17, 2011 at 6:17 pm
    The latest drivers and this tip are very helpful. If only AJA didn’t hate me for trying to go cross-platform with DNxHD…. Playback for that still seems pretty awful.
  • Tom Daigon
    November 17, 2011 at 7:17 pm
    Thanks for the heads up about DNX. I havent tried decoding or encoding yet, but I will this afternoon. It really seems next in line to replace Prores since Apple dropped the ball on the professional video community. Wish me luck!
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Tom Daigon
    November 17, 2011 at 7:43 pm
    UPDATE
    Josh, you are correct. I converting a 30 sec Prores master in AME to DNX. Then I made a sequence from that clip. I set the Kona 3 to Aggressive Cace and tried both HIGH quality and MEDIUM quality. I played it on the timeline and PrP struggled with both settings, dropping frames left and right. Its time to communicate this to AJA since DNX is a real up and comer. Thanks for the info!
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Josh Pappas
    November 17, 2011 at 10:16 pm
    On the bright side, AJA is showing support for DNxHD in their Ki Pro products, which makes me think they’re willing to support it fully in their I/O devices. One doesn’t make much sense without the other.
    Thanks for confirming the issue and helping get the word out!
    Josh
  • Tom Daigon
    November 17, 2011 at 10:21 pm
    Really? Is the Ki Pro Mini also supporting it? I think that device could be a great way to do a real time dump from the PrP time line thru the Kona’s SDI output into the Ki Pro Mini SDI. This could avoid some of the long render times folks deal with for long form or graphic intensive projects. Kind of like the old dump to tape we all used to do .
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
