Activity Forums Adobe After Effects New After Effects user needs help!
  • New After Effects user needs help!
    Posted by Suzan Elzein on November 6, 2021 at 9:56 pm
    Hello…
    I am trying to learn how to create cool stuff in Adobe After Effects. But I am facing some issues:
    1- After I finished my illustration in Illustrator, I imported the Illustrator file into After Effect, but it seems that my illustration got pixelated ( not too much, but it shows when i zoom in). how can I fix this problem? (knowing that I set the resolution of my Illustrator file at high resolution)
    2- I have a 2d shape done in Illustrator and I wanna make it 3d in After Effect, but when I click on the Geometry options, I cannot see the Extrusion Depth option, all what I see under the Geometry Options is the Curvature and Segments options… Any ideas how can i make 2d imported shape from Illustrator to be 3d in After Effect?
    Thanks…
    Suzan Elzein replied 4 years, 10 months ago 3 Members · 3 Replies
  • Meng Zhiqun
    November 9, 2021 at 4:53 am
    1. You need to enable continuous rasterize.
    2. You need to change your renderer for that comp to cinema 4d renderer. You can access that by Ctrl K or Cmd K, 3D renderer.
  • Eric Santiago
    November 9, 2021 at 2:26 pm
    Don’t forget to convert your vectors to shape layers.
    There are a ton of YouTube tutorials on this.
    Also, prep your vectors in AI accordingly.
  • Suzan Elzein
    November 9, 2021 at 5:53 pm
    thanks 👍
