Activity Forums Apple OS X Networking problem with PCs
  • Networking problem with PCs
    Posted by Ed Stevens on December 9, 2005 at 10:44 pm
    I have a network setup with 5 PCs and a G5. The G5 can talk to the PCs but I cannot get the PCs to see the G5. What am I doing wrong?
    Thanks in advance
    Mark Sloan replied 20 years, 9 months ago 3 Members · 2 Replies
  • Curtis Thompson
    December 9, 2005 at 11:40 pm
    hello…
    check that you have windows sharing enabled in your sharing control panel…
    sitruc
  • Mark Sloan
    December 10, 2005 at 2:20 am
    The other issue is to check what your Workgroup is set to. If it gives you problems just check your Mac’s IP address and you can connect that way using Run function from your start menu. Just type \\111.222.333.444 whatever the IP address is.
