Activity › Forums › Apple OS X › Networked rendering
  • Networked rendering
    Posted by Colin on September 8, 2005 at 4:38 pm
    Anybody know any means to utilise the processing power of a number of Macs by networking them together through ethernet or Firewire?
    I think one can do this through using an X serve + the software Xgrid – but this is way beyond my budget. Surely there is some simple software utility that one can use to assign rendering tasks to another computer on ones existing network ?
    Thansk in advance for any advice offered.
    Colin
    Colin replied 21 years ago 2 Members · 2 Replies
  • Tony! Hulette
    September 8, 2005 at 7:11 pm
    The applications need to support network rendering in most cases. After Effects already has a solution for this, as do some 3D applications. You might want to check with your software developer to see if they have a solution for you. It would help to tell us what application/s you’d like to use network rendering with.
    Tony!
  • Colin
    September 8, 2005 at 9:18 pm
    Tony,
    I’m using Final Cut Pro + Compressor [ Apple] + Photoshop + PTMac.
    Regards,
    Colin
