Activity Forums VEGAS Pro Networked Drive
  • Networked Drive
    Posted by Will Moffitt on April 5, 2006 at 12:22 am
    What is the best way to have 2 computers use material on a firewire drive? I would like to be able to have vegas on 2 computers using material from the same drive or one vegas system digitizing footage in while the other is using footage.
    Can it be done?
    Donatello replied 20 years, 5 months ago 2 Members · 1 Reply
  • Donatello
    April 5, 2006 at 12:37 am
    if the clip is being capture ( as in during capture) you don’t have access to the clip.
    also depending on the drive if you are accessing other clips on same drive as you are capturing you might drop frames during capture – you’ll have to do a test.
    i find most clips will NOT play back at 29.97 over 100Mb network. i get around 12-14fps over network ( doesn’t matter if it’s a external or internal shared drive)
