Activity Forums Adobe After Effects Network Rendering connection issue…
  • Network Rendering connection issue…
    Posted by Jason Shreve on October 7, 2005 at 6:03 pm
    I’m too pumped. I’ve just set up a little gigabit network with 2 Dual G5’s & a NAS. It’s smokin’! But when I try to add my G4 powerbook into the mix by setting up a “watch folder” I get an “After Effects error: You do not have read/write permissions for this folder.”
    So that kinda doesn’t make sense, since I can write to, edit, whatever any file on that drive from my notebook. Then when I quit AE, I get this interesting little tidbit: “After Effects warning: Tracked Memory leaks detected file buffer: 40960 bytes leaked (23
    Tristan Gieler replied 13 years, 3 months ago 3 Members · 2 Replies
  • Jasontoth
    October 19, 2005 at 5:10 am
    I need help on this exact same issue 🙂
    Or is it 🙁
    Thx in advanced
  • Tristan Gieler
    May 29, 2013 at 6:33 am
    You want to make sure your watch folder has the correct permissions. I’m on a mac, but in case you’re on a PC there must be a similar process.
    On a mac:
    go to the watch folder and het CMD+i to open the info box. at the bottom, in the ‘sharing and permissions’ section, make sure you have read/write enabled for all computers in the network.
    That should do it 🙂
    I think it might also be the case that if your watch folder is inside another folder(s), the parent must also have read/write enabled. But don’t quote me on that.
    Hope this helps 🙂
