net render shared storage
i have the net render set up with about 15 clients and a server… all is working well…
question is about shared storage for the render results. currently the resulting image sequence obviously goes to the machine running the NET RENDER server… ultimately this isn’t nearly as handy as if it were able to save the results to a specific path on our shared storage server… this would save us the step of moving the results for each render…
i realize this isn’t a documented feature, but is there any good workaround or way to modify the behavior of the net render server to accomplish this???
thanks.
