Activity Forums Maxon Cinema 4D NET RENDER Problem – Help
  • NET RENDER Problem – Help
    Posted by Darren Kunkel on September 2, 2009 at 5:45 pm
    Guys-
    I’m setting up NET RENDER v.10 in my lab. This is probably very simple, but I CANNOT get ANY changes to RENDER SETTINGS to get applied to the job.
    After making the RENDER preferences change (in my case, changed output to be a Quicktime movie instead of the default .TIF), I re-copied the entire project with all files to the USER directory as required.
    Is there a trick to applying the new RENDER PREFERENCES to a job handled by NET RENDER?
    THANKS in Advance-
    -Darren
    Darren Kunkel replied 17 years ago 2 Members · 2 Replies
  • Randy Johnson
    September 2, 2009 at 8:06 pm
    Try saving the project with a different name.
    /randy
  • Darren Kunkel
    September 2, 2009 at 11:22 pm
    Hey Randy-
    thanks so much for fielding such a goofed-up question.
    That worked……
    Again, thank you for the quick response!
    -D
