Activity Forums Adobe After Effects Nesting vector layers for 3D space
  • Nesting vector layers for 3D space
    Posted by Karim Daire on July 27, 2006 at 8:46 am
    everytime I use Illustrator maps to show roads with stroke or gradually blend in cities or whatever to be then placed in a PAL-Comp as 3D layers to animate the camera on I get the same problem. Its something about the “continously rasterize” I don’t get.
    If I use a composition with the Illustrator-Map and path/city animation as a 3D Layer in another compostion its either blurry when zooming in or my 3D layer transformations are lost when I turn on the “continuously rasterize” button. Since its vector graphics I never do my map composition too much larger than the PAL comp. Which way is best to keep the vectors in a pre-comp not being rasterized before the final render??? I saw tutorials on this and thought this should work, so am I doing something wrong or do you need to place the AI-Layer itself in our final comp??
    Thanks for any help,
    Karim
    Karim Daire replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
