Activity › Forums › Apple Final Cut Pro Legacy › Nesting Conundrum
  • Nesting Conundrum
    Posted by Francis Sheehan on August 9, 2006 at 2:42 pm
    I am onlining a show which contains nested sequences. The original nested sequences are 5 hours long and there are only a few shots from them in the final show. I am conforming the show and FCP wants to put the entire original nested sequences back online. I am really close to filling up my 5 terabytes of disk space.
    I am looking to
    Craig Seeman replied 20 years, 1 month ago 3 Members · 3 Replies
  • Todd Reid
    August 9, 2006 at 4:15 pm
    just a thought….
    can you navigate into the nest and select the few shots you need, move them out of the nest, maybe in a temp sequence.
    Then you might be able to minimize your recapture. You mentioned that you don’t need most of the nest, so this might work.
  • Francis Sheehan
    August 9, 2006 at 4:45 pm
    From what I am gathering from the stuff I am reading, I am not the first to get hammered by this one. Lesson learned! The offline editor did his best in most cases to eliminate the nested sequences. I will try what you have offered as a solution and hope for the best. The only problem I have is that I have already captured most of the footage for the show and I have to figure out a way to create new master clips without going through the standard make offline project business.
    Thanks for the reply,
    Francis
  • Craig Seeman
    August 10, 2006 at 2:44 pm
    If you drag the nest into the browser you can Apple or Option drag (I forget which) back into the timeline and you should get the individual shots (“de-nested”) that you need.
    This kind of thing is one of my pet peeves about FCP having been an Avid editor for years. If you take a project offline and then at a later point try to capture just the final sequence, it may well try to recapture the entire clips rather than just the sections in the timeline. I believe one of the “fixes” in 5.1 is the ability to media manage an offline project though.
