Activity Forums Apple Final Cut Pro Legacy Nesting benefits?
  • Nesting benefits?
    Posted by Kent Beeson on April 20, 2006 at 6:38 pm
    Hello:
    Is there ANY benefit to nesting an entire sequence when finished editing before printing to tape? I’ve 3 layers of video and 4 channels of audio, in an hour and 5 min sequence and I am dubbing to tape using DSR-11. Should you still need to do an audio mixdown after nesting as well?
    Thanks much
    KB
    Joe Murray replied 20 years, 4 months ago 6 Members · 9 Replies
  • 9 Replies
  • Walter Biscardi
    April 20, 2006 at 6:58 pm
    [Kent Beeson] “Is there ANY benefit to nesting an entire sequence when finished editing before printing to tape?”
    For just printing to tape? no. If you want to apply some filtes across the board in one shot, then yes. Such as Broadcast Safe or Levels or something like that. But for just laying out to tape, nope, no need.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Kent Beeson
    April 20, 2006 at 7:00 pm
    OK thanks thanks for help.
    KB
  • Ben Holmes
    April 20, 2006 at 7:59 pm
    Walter’s right – no need. Can I just add that sometimes I have found nesting causes instability in FCP – I’ve noticed a few out of memory errors after doing it. Don’t forget that nesting in effect causes you have MORE open sequences, something that inevitably places more load on the system.
    So – in effect, nesting is more likely to make the print to tape process LESS stable. Whilst it may give you a neater looking timeline, all you’re doing is sweeping the mess under the carpet, not actually clearing it up.
    If you have problems with your print to tape, instead of nesting you should export the timeline as a quick time movie (current settings) and place the resulting single clip in a new timeline – if you have the spare capacity on your drives.
    Ben
    Editec Broadcast Editing Ltd
    EVS and FCP specialists
    Current Mac systems All Dual 2.7Ghz with Kona 2 and Digital Voodoo cards, 6Gb Ram, Sapphire, SCSI320 Medea and Huge Arrays.
    FCP projects include Sky TV coverage of the Ryder Cup and US Open Golf – Live OB specialists. Edit/slomo vehicle.
    http://www.editec.co.uk
  • Kent Beeson
    April 20, 2006 at 8:09 pm
    Very good to know – thank you.
    KB
  • Winston Cely
    April 20, 2006 at 8:12 pm
    I’d like to 2nd the above comments. Though there are good reasons to nest, such as multilayer effects, nesting seems more trouble than it’s worth. Just yesterday I had a major problem because of nested sequences in a timeline (Time Ramping issues were also at fault) . If for whatever reason, you’re having a crazy amount of dropped frames on edit to tape, or print to video, I would export @ current settings a self-contained video and import it into it’s own project. This has saved us hours of headaches.
    Winston A. Cely
    Editor
    Envision Response
    Seattle, WA
  • Kent Beeson
    April 20, 2006 at 8:16 pm
    OK, once I import the QT mov of my sequence, before I print to tape, do I still need to do an audio mixdown?
    KB
  • Randyp
    April 20, 2006 at 8:22 pm
    Do audio mixdown before making QT.
  • Kent Beeson
    April 20, 2006 at 8:30 pm
    Thanks to all for the help…
    KB
  • Joe Murray
    April 22, 2006 at 3:37 pm
    If you’re exporting a Quicktime with 2 channel audio, your effectively mixing down on that export. No need to mixdown once you reimport.
    Joe Murray
