Activity Forums Apple Final Cut Pro Legacy Nested Sequences
  • Nested Sequences
    Posted by Brad Elliott on December 14, 2006 at 8:07 pm
    My understanding is that when you update clips within a nested sequence your parent sequence will always reflect those changes. Everything I have read in the manual leads me to believe this is an absolute.
    Is there some sort of setting that would prevent this from happening? I have made changes in a nested sequence and rendered it and the changes are not being reflected in the parent sequence when I play it. If I play the parent sequence in the Quick viewer I can see the changes I have made but they don’t show up when I play the parent sequence in a normal manner.
    What am I missing?
    Brad
    Joe Paolo replied 19 years, 9 months ago 2 Members · 1 Reply
  • Joe Paolo
    December 14, 2006 at 9:21 pm
    Often the parent clip will not release the old render. Toggle the nested clip off on to force a render and it will update.
    joe
